Advanced Wheels
Discussion in 'Prime Main Forum (2017-2022)' started by gt1jimi, Sep 12, 2018.
  1. gt1jimi
    gt1jimi Junior Member
    Central Maine
    We are the proud owners of a shiny new Prime Advanced in Hypersonic Red. My wife finally let go of her '04 Prius (222K miles). Everything about this new model is simply fabulous, except . . . yeah, the wheel covers are pretty cheesy.
    My first idea is to pull the pizza covers and go with the stock wheels. I'd like to dress them up with some red lug bolts, but my question is: Has anyone done this? Considering the general lack of love for the stock wheel covers on the forum, I can't believe that someone hasn't.
    So, any experiences? Anything to look for, or look out for? I await the accumulated wisdom of the group. Thanks.
  2. Washingtonian
    Washingtonian Senior Member
    715
    616
    I think a lot of us have removed the plastic wheel covers, altho I doubt anyone has installed red lug nuts. What you need to do is buy a set of the Toyota disks that go in the center if the aluminum wheels. If you look at the threads on wheels you will find the part number.
  3. Mark57
    2,945
    2,736
    OK
    Welcome and be sure to update your vehicle type in your profile.
    The center caps from Amazon . . . .
    Manufacturer: Toyota
    Part Number: 42603-52170
    Part: Center Cap
    Part Notes: With gloss black.
  4. slothsandwich
    slothsandwich Junior Member
    27
    Denver
    2018 Prius Prime
    I would suggest upgrading to new wheels. Lots of stock OEM sizes that compare in similar weight. if you're willing to shed a couple of miles per charge, plus sizing to 16" or even 17" is always an option. The OEM wheels are butt, no matter how much lipstick you put on/near them.
  5. Delbert
    Delbert Junior Member
    Lawrence, KS
    Anyone know how I could get my hands on the European Prime wheels? Screen Shot 2018-07-27 at 4.19.34 PM.png
    Nathanimal and Mendel Leisk like this.
  6. DavidA
    2,328
    1,812
    Chicago western burbs
    Wheel covers were never installed. I asked for the wheel covers to remain in their factory plastic bags, where they still are, unopened. The caps I popped in as I walked around the car at pickup. The salesperson was somewhat amused. She asked where I got those, and I just smiled (hint: Amazon).
  7. Mendel Leisk
    38,653
    Prius Plug-In was the only Prius with decent 15" rims:
  8. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Reading the description, those fit a gen3 Prius not a gen 4 Prius, and the gen2 is a different size also.
    What do they measure in diameter?
    It’s my understanding that Yaris center caps do fit so it makes it confusing.
  9. Washingtonian
    715
    616
    Mine measure 2.1 inches or 5.25 centimeters using a cheap plastic rule.
  10. Mendel Leisk
    38,653
    Centre caps are tricky: beside diameter, there's also retainer clips that click into a groove inside the bore. Between 3rd and 4th gen that groove location shifted, meaning 3rd gen caps don't fit properly in 4th gen: the diameter is the same but the clips don't lock properly.
  11. SeattleBicycler
    SeattleBicycler Junior Member
    35
    Seattle
    The OEM wheel covers are designed for aerodynamic wind flow for lower wind resistance. Their is a science behind their looks.
  12. Mark57
    2,945
    2,736
    OK
    That IS the correct number. 42603-52170. That's the info off my order and they're ON my 2017 Advanced. Several threads here with others quoting the same part number. Never rely on an Amazon description. Search Toyota parts sites like the one I posted below, then search price. See below Toyota dealer.
  13. Mendel Leisk
    38,653
    Maybe. I'm skeptical though. It'd be interesting to see a with/without test: I suspect the variation (if any) would get "lost in the noise".
  14. gt1jimi
    Central Maine
    I am of the mind that if aerodynamics were the priority, Toyota would have implemented more aggressive streamlining, such as used in the first generation Honda Insight.
    One can only guess as to the motive behind the stock wheel covers. I cannot see how the "high tech pizza with every other slice gone" design would yield lower drag than, say, smooth wheel covers. It may very well be nothing more than a styling exercise. As for the rear fender skirts not being a part of the Prius design, I can only express my profound gratitude for small favors
    slothsandwich likes this.
