Advice for cleaning the steering wheel?
Discussion in 'Generation 1 Prius Discussion' started by hybridtwins, Sep 7, 2009.
  1. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    I'm talking about getting out stubborn ground-in grime that's been building up pretty much since Day One on my 2002.
    I've done a fair job using Simple Green cleaner, a roll of paper towels and a lot of elbow grease. But I wondered if anyone has a better suggestion.
  2. joeman
    joeman Member
    239
    Raleigh, N.C.
    Mark,
    I would try a really good vinyl cleaner. I would use a soft cotton towel instead of paper towels. You will get more traction with the towel. I have had good luck with vinyl cleaner in the past, possible what your using may work just as well????
    Joe
  3. bbcb
    bbcb Junior Member
    Houston
    When you ask about automotive cleaning products, be prepared for a religious debate.
    I've always found good results with 303 Aerospace Protectant. I get mine at Ace hardware ~$11/bottle.
    With a microfiber towel, it cleans it right up - what's more, no greasy residue nor oily shine like armor-all will leave *and* it leaves a satin finish, so the dash is not blinding in the afternoon sun. Additionally, it won't dry out the vinyl like Simple Green will.
    I still use SG to degrease under the hood, but after the rinse and it dries off, I use the 303 there too to keep the rubber supple and with a dealer-prep look.
    A little work, makes working under the hood cleaner and less frustrating.
