Advice for parent's 07 Prius: P3000, P0420, P0A80, C1311
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bgustafson, Jan 14, 2020.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Hey everyone, my parent's 2007 Prius with 245,000 miles is finally showing signs of a failing traction battery. Up until now, they've been going strong on the original battery. Along with the traction battery codes, Techstream is also giving me code P0420 "Catalytic System Efficiency Below Threshold (Bank 1) which is concerning.
    My father just put new snow tires and brakes on the car, so he's weighing his options a bit. I have a local reputable hybrid battery specialist who could either a) install in a junkyard battery or 2) install a 3rd party reconditioned battery. I'm aware of the implications of these reconditioned batteries, as I have already done so on one of my previous cars.
    Personally, I don't have the patience or time to mess with swapping cells; so my main concern / question right now is the P0420 code - is this possibly related to the failing traction battery? Or are we looking at needing to replace the CAT at the same time as the battery? If indeed a replacement may be needed, at that point it likely won't be worth putting the money into this car.
    Advice would be appreciated.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    I had a 2005 Prius that I drove for over a year with the P0420 code. Mine had essentially zero effect on how well the car performed, as it still got 48-51 mpg. Complete exhaust replacement assemblies are available on ebay for about $300-350 which are straight bolt in at the oem bolt locations. 2 bolts at the exhaust manifold and 2 bolts near the passenger rear tire area. I guess it all depends on whether Illinois allows aftermarket replacements.
    As for the HV battery, I think you have that under control.
    Priuslover09 and M in KC like this.
