Advice on buying 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by parbarry, Oct 24, 2010.
  1. parbarry
    parbarry New Member
    Minneapolis, MN
    Hello:
    I put down a deposit on a 2010 Prius II that has only 7400 miles on it. It was a local corporate car and purchased in December of 2009. I'm am buying it from a reputable local dealer, but it is not Toyota Certified. The Car Fax record is clean.
    Would you suggest I have a mechanic check it out before I pick it up? Or, would it be a safe purchase because it is still under warranty?
    Thank you!
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    What does your gut tell you to do? If it's screaming to have it checked, then do it! BTW, is there really such a thing as a reputable used car dealer?
  3. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    :thumb:
  4. Blackwlf
    Blackwlf Junior Member
    22
    Weare, NH
    I agree with going with your gut. Also go with your nose. Does the car dealer smell like too much deodorant? Often times that is done to cover up someone sweating while lying.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
