Advice on buying a used 2016 Prius v
Discussion in 'Prius v Main Forum' started by NEClassic9728, Mar 10, 2025.
  1. NEClassic9728
    NEClassic9728 New Member
    I am looking at a used 2016 Prius v with 45k miles, asking price is $16.4k. It has a clean record, one owner. I live a few hours away from the sale location and I'm not sure if I'll be able to find a mechanic in that area that knows Priuses well. I'm wondering what to ask for in the pre-purchase inspection. Is there a way to test the battery health, and any tips on other things to be looking for? Thanks!
    50,812
    the big thing is a clogged egr circuit and blown head gasket. my main concern would be if someone rolled back the odometer.
    if it really only has 45k, you could get a hybrid battery health check at a dealer.
    but keep in mind that many of these engines burn oil, and the egr circuit needs to be cleaned every 50k or so.
    NEClassic9728 likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,293
    5,664
    Texas Hill Country
    Many gen3s blow head gaskets (easily hidden by sealer for a couple of months), have brake by wire master cylinder failures and can have inverter failures.
    There are really no pre purchase inspections that can pick up sealer or potential master cylinder or inverter failures.
    If you keep the car a few years the hybrid battery will need replacing on your watch.
    It's easy to roll back the odo; a guy on this forum does them for people by mail.
    Don't buy the car to save money on gas. First the mpg of a v is 42mpg max, less than a standard Prius. Any single repair above will negate gas savings. For $16.4k it's not a risk I would take.
    #3 rjparker, Mar 11, 2025
  4. MAX2
    MAX2 Senior Member
    1,344
    422
    101
    Third planet from the Sun
    You can check the condition of the high-voltage battery using the Hybrid Assistant or Dr. Prius programs by installing them on your phone.
    You will also need a good OBDII adapter.
    You will hardly be able to determine the condition inside the engine, EGR, or brake system by eye. This requires a more thorough approach.
    Rolled back mileage? But where was this car serviced? There must be some history, insurance, etc.
  5. fifty_mile_commuter
    fifty_mile_commuter New Member
    Fort Collins, CO
    Soooo...I just put a hold on a 2012 Prius v that has < 30k on Carvana. Is there any way to tell if someone has rolled back the odometer?
  6. MAX2
    MAX2 Senior Member
    1,344
    422
    101
    Do the officials have a service history?
  7. rjparker
    9,293
    5,664
    Texas Hill Country
    If the mileage is legitimate the car was not driven for years or was driven less than 3k miles a year.
    The traditional way is to buy a Carfax service report based on the vin. It could have been sold in late 2011 so it is 13-14 years old. With less than 30k you would expect to see oil changes about every year with mileage increasing maybe 2.5k miles a year.
    Toyota provided two free oil changes within the first two years. Carfax submissions are optional at most places and are never done by diy'ers. Obviously no carfax reports after initial purchase and the first two oil changes leaves an opportunity to roll back the odo.
    If you are a fifty mile each way commuter you will put 30k miles a year on the car. Expect a $2500 hv battery and a $2500 brake booster in the first year or two. If the coolant was not changed often expect a head gasket in the same period.
    #7 rjparker, Apr 2, 2025
  8. fifty_mile_commuter
    Fort Collins, CO
    Just a quick update, I opted out of the Prius V.
    After doing even more lurking than usual on this board, I found recommendations for Paul at Boulder Hybrids and we have a plan for an engine replacement, so I can fix known problems on the car I already love for much less than it would cost to roll the dice on a new-to-me used car.
    I am a 50-mile one way commuter, but now only twice a week. Pandemic silver lining.
    Thanks all for your replies, and for keeping PriusChat one of my favorite places on the internet.
