Advice on code throwing original HV battery in low-ish mileage 2008
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Carmen TheWonderDog, Sep 30, 2025 at 10:35 PM.
  1. Carmen TheWonderDog
    Carmen TheWonderDog Junior Member
    Central IL
    I’m the 2nd owner of this relatively low mileage (120-140k? Ish) 2008 Prius that hasn’t given me any problems but for my 12v battery abuse, and taking a beating from a couple natural disasters (‘totaled’ 2ce so far, but mechanically & structurally sound, just not pretty).
    Well, coming home from a 40min drive, I was dazzled by a light show of the triangle of death & probably others, but that one was enough to make me pull over on the country highway. But, this was the one time I didn’t have my phone, so I started it back up to get to somewhere I could get help. And, that’s where it truly gave up the ghost; electrical turns on, but no motor, inoperable.
    My mechanic said it had HV battery codes alight, but dopey me, I didn’t ask which. So, I’m at a crossroads:
    - order by mail a refurbished battery for $1k and just DIY replacement w/o ever diagnosing the battery (core return postage paid)
    - same joint in FL, $2k for new
    - fork over the $ and have the nearest tech drive the 2.5hrs (at least $200 to show up), then worst case scenario, if still need a refurbished battery, they’ll charge $1400 plus the service call.
    I did toy w/ the idea of getting an economy scanner compatible w/ iPhone & android , as we have 2 gen2s and a gen3. But, I don’t expect I have either tools or know how to do much w/ the info, besides perhaps, drive the battery the 2.5h for repair, if it’s more likely to be in better shape after repair vs reconditioned. ???
    My battery hasn’t been garaged in brutal hot humid summers & freezing winters & car has often only been used a few times a week for a few miles/trip (fill up tank once a month, or 2 months? if not busy).
    Ideas? Advice? Comments? Questions?
    [My other dream plan is to also buy a low mileage 1 owner all maintenance records PiP that’s been in comfortable weather its whole life, as well. Then use one for business. Would be nice to have a backup vehicle & nice to have more justification for solar panels. PiP would essentially be electric almost all of the time, unless going out of town (rare). I figure stock isn’t going to get any better than now w/ the sun downing of the fed clean car credit. Only sticky bit is I’ve only bought cars from private sellers before, in person - only 2ce. And if buying a car from a distance, finding a good hybrid mechanic to do a thorough pre-purchase inspection, so I don’t have the willies about buying sight unseen. Oh, and dealing w/ dealers & dealers’ pricing, the horror, eep!!!]
    Complex enough for 1 thread?
    #1 Carmen TheWonderDog, Sep 30, 2025 at 10:35 PM
    51,548
    you've got a lot going on there, i'll try to take it in order:
    1) you could ask for the codes, or have it scanned again.
    2) you could buy an autel maxi 200 for $60.
    3) get a free 12v load test at most auto parts stores before reading the codes.
    4) once you have the codes it's decision time.
    5) if it is the battery, keep in mind that a repaired battery and reconditioned are the same thing.
    you're replacing bad modules and (hopefully) balancing the entire battery.
    there is no such thing as reliability with this process because the rest of the battery is still old modules which can go at any time.
    you're paying for a warranty. the more you pay, the longer the warranty. if (when) you need it, you have to hope the company is still in business, and that they honor it.
    keep in mind that these batteries like to be used, and cars that are infrequently driven, or rack up low miles tend to have the earliest battery failures.
    also consider a new battery, which will likely last longer than the rest of the car.
    on the pip purchase, keep in mind the blown head gasket issues of gen 3.
    all the best!
