advice plz: might buy 2003 Prius
Discussion in 'Gen 2 Prius Main Forum' started by lsbf, Sep 13, 2011.
  1. lsbf
    lsbf Junior Member
    Massachusetts
    I'm contemplating buying a 2003 Prius with 125,000 miles. Reportedly, it's mechanically sound, always serviced at a Toyota dealer. (I'll have my mechanic check it out.) The battery was replaced at 85,000 miles. Any thoughts or advice appreciated.
    Thanks in advance from Prius newbie.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Battery replacement sounds good. There are a few more quirks with the 2001-2003 models, such as the sticky HCAC valve, higher transaxle failure rate, steering rack. Take it for a good long test drive and make sure that the mileage is in the 40s with a mild driving style. If it just doesn't feel right, pass. Purchase price should be in the mid thousands, $5K +/-
  3. kenmce
    kenmce High Voltage Member
    1,532
    508
    NY
