Advice Trade in or repair
Discussion in 'Gen 3 Prius Main Forum' started by Raphmanprius, Apr 16, 2024.
  1. Raphmanprius
    Raphmanprius New Member
    Georgia
    Hi I’ve been following these forums for a decade now. My 2012 Prius with 119,460 miles needing a brake booster assembly and brake master cylinder. Parts, labor and taxes it’s $2700. I went to a couple of local shops and either it will be more or they don’t feel like they can do the work.
    Reading on future issues I’m tempted to trade in. My options seem to be:
    1. Repair- I’ve owned this since brand new.
    2. Trade in and get a new model.
    3. Trade and get a Ford maverick
    I would like some advice from some previous Prius owners.
    Thanks
    49,492
    if you haven't already, the head gasket might need replacing at some point, possibly the whole engine.
    no one can predict it, but if you can afford to, i'd get the maverick.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    706
    276
    Maine
    Why would you think of going from a Prius to a Ford maverick?
  4. Raphmanprius
    Georgia
    I know I’m usually getting mulch and pine straw for the yard twice a year. Currently using my Prius to make trips to get items . Also the maverick hybrid engine makes it very close in mpg. I work from home so not really worried about a slight dip in mpg.
  5. Raphmanprius
    Georgia
    It’s first repair I’ve ever had to be done.
  6. Tombukt2
    Tombukt2 Senior Member
    9,139
    1,586
    Durham NC
    You need to dump the generation 3 You could risk it on a later model generation 4 but that may be as much of a risk you'll find out for get something like a bolt I'm not sure what's up with the Maverick Is that electric or hybrid or something certainly a Ford is not going to be in the gas mileage arena.
    s11 likes this.
  7. Mendel Leisk
    38,727
    If you keep it do a full EGR (including intake manifold) cleaning ASAP. It's a little late in the day, but not by much.
    Raphmanprius likes this.
  8. Raphmanprius
    Georgia
    Maverick is small hybrid pickup truck that gets 42 city/ 34 highway mpg.
  9. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    You will get more for a gen3 repaired than needing a brake booster. The value goes way down otherwise.
    Fix the booster and then sell it privately. Buy the car you want.
  10. bettergolf
    bettergolf Active Member
    427
    339
    Sanford NC
    I'm also considering a Maverick.hybrid mostly because as I get older it gets more difficult to get into and out of the Prius.The Maverick sits up higher..I know the gas mileage isn't as good as the Prius, but it's not bad. I'd rather have the Rav4 Prime, but not for $40k-50k. I'm still good to keep the Prius another 2-3 years though...who knows what will be available by then?
  11. Tombukt2
    9,139
    1,586
    Durham NC
    I'm about to start on raising my Prius I hope this weekend 1.7 in or so should take about 2 hours
  12. ColoradoCrow
    ColoradoCrow Active Member
    973
    392
    Leawood, KS
    I
    off road prius kit Tom?
