Aeronvironment EVSE installed finally
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by devprius, May 31, 2012.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Thanks to cwerdna, I was able to get an Aerovironment EVSE for a really good price. My electrician installed it yesterday. Unit works perfectly. While the unit is probably overkill for the PiP (it's a 30A unit capable of 7.2Kw and the PiP only pulls about 2Kw), it was a lot a cheaper to buy this unit and have my electrician put in than it would've been to have Leviton come out and put in their 16A unit.
    My only complaint is that the cord for it is only 15 feet long. I have e-mailed Aerovironment to see what it will take to have a longer cable put on it. I know that it's an option available when you order them. I just don't know how easy it is to get a longer cable once the EVSE has been installed. It looks fairly easy to swap out the cable.
    I'm torn whether to cover up the Nissan nameplate on it...
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yay! Glad to hear it worked out for you. I was beginning to wonder...
    It really is too bad that Toyota put the inlet on the rear of the car. Given the costs we've heard of trying to buy a J1772 cord + connector, I doubt it'd be cheap to retrofit. :(
  3. devprius
    devprius /dev/geek
    979
    291
    It's taken me this long to get my electrician out to do the work. I'm very happy that the unit "just works" like it's supposed to. Very pleased with it so far.
    TusconEV has an 8-meter cord with 6AWG wiring & J1772 head on it for $250, so I can go that route if necessary. In the meantime, I'm just backing the car into the driveway and plugging in that way. It's a minor pain, but certainly less than the pain of having to pull the L1 EVSE out of the car every evening, and put it back it back in every morning...
    51,155
    how much is the unit? every once in a while, i could use the 1 1/2 hour charge.
  5. devprius
    devprius /dev/geek
    979
    291
    Retail cost is $900. Requires a hard-wired installation. If you have an unused 240V outlet (like a dryer outlet), you can send your L1 unit into pEEF to have him convert it to run off of 240V or 120V. You just need to use the right adapter for the plug you are using. Cost is around $300 for that. Alternatively, if you are good with electronics, you can build your own L2 unit for about $500. Lowes and Home Depot carry a variety of L2 units, some of which can be plugged into an unused 240V socket.
    I don't need L2 charging. But I did want an EVSE that was always connected at home so I could leave the portable L1 unit in the car. Installing the L2 was more about convenience for me. Or, as some would put it (myself included), personal laziness.
    Totmacher likes this.
  6. bisco
    51,155
    thanks dev, i like the sound of the peef route price for the amount i would use it, but you have to send it to him and wait a coupla weeks. i can't stand the thought of not having it for that long but i think he said in the future, he'll have some he can send out first and credit you when he gets yours.
  7. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    If you buy a longer cord, I'd like to buy your old cord, if it comes with the connector.
  8. devprius
    devprius /dev/geek
    979
    291
    That sounds doable. Planning on making your own EVSE? Is 15 feet long enough for your needs?
  9. Rebound
    3,972
    2,626
    Portland, OR
    Yes, and yes.
  10. mrbigh
    3,686
    699
    Long Island, NY
    I purchased their cable assembly for my Open-EVSE and it's great.
  11. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    Thats exactly where I am at with it. I hate having to lug it in and out of the car. My plan is to get one of my electricians from work to swing over after work and pull a 220 from my panel (literally 10 inches away). So I got the 220 portion covered. Now I'm just looking for a decent quality L2 for a good price. Any recomendations?
  12. Rebound
    3,972
    2,626
    Portland, OR
    I mounted my Toyota EVSE to the side of my house. Attached is a photo of my "installation". My 1920's home has a detached garage, so I bolted up to the side of my stucco house. Fully wife-factor approved.
    Personally, I think EVSE's are overpriced right now and I'll install a 240V unit when they're cheap, BUT I did consider buying this $500 unit.
    MCDamavandi likes this.
  13. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I don't see it as overkill. I see it as early preparation for your next, more powerful, car.
  14. terrylowe
    terrylowe Junior Member
    79
    24
    Mississippi
    I just put in the OpenEVSE version. Very fun to do and works like a charm.
