aerosol cans in rear compartment?
Discussion in 'Gen 3 Prius Main Forum' started by davidwlowe, Nov 21, 2010.
  1. davidwlowe
    davidwlowe New Member
    tustin, ca
    What is the reason for the suggestion not to keep aerosol cans in the rear compartment?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It heats up when the sun shines in.
    Tom
  3. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Keep it in your backpack and its fine. Be sure to tag only when cops aren't around.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    On a similar and less potentially disastrous note, I would
    caution against having canned soda/carbonated beverage
    lying around in the car for long periods.
    I had one split open after a long hot-soak in a shadeless
    noonday parking lot. I was driving the car at the time when
    the can let go -- I wouldn't say exploded exactly -- with a
    Whoosh! The hissing sound of the out-rushing soda was truly
    alarming. Fortunately, the split was not facing straight up.
    Nonetheless, hot, pressurized soda was forcefully sprayed
    all over the rear seats, front seat backs, and roof liner...
    a real mess, that I never was able to completely clean up.
  5. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    A few years ago a friend had a can of spray foam insulation explode in the back of his trans-am due to the heat build-up in the closed up car. To make a long story short -- they totaled the car.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    And just for those northerners, some spray cans contain water. It will freeze. The can will burst - slowly. When it thaws out it will make a mess. For example, glass cleaner. Ditto for pop cans. They go POP (guess that's why we call them pop cans ;) ). They make a mess immediately even when cold.
