Affected by the Recall
Discussion in 'Fred's House of Pancakes' started by smdailyjournal, Feb 15, 2010.
  1. smdailyjournal
    smdailyjournal New Member
    San Mateo
    Hello Everyone, i'm a journalist for the San Mateo Daily Journal, and I'm writing about the recent recall for the accelerator pedal sticking and slowing the return to idling speed.
    I'm wondering what effect that has had on you as Toyota drivers/enthusiasts: If it has affected your views/confidence in Toyota, any worries or concerns, or if possible someone who's vehicle has this specific problem, what was it like to experience?
    Thanks all for your time. If you are comfortable, when you reply if you could please leave your name the city in which you live so I can properly quote you, that would be terrific. If you want your answer to be more discreet than out in the open on this forum, my email is bgrabianowski at gmail. Thanks again.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You do realize that the Prius is not included in this recall. All Prius are built with the Denso accelerator pedal, which has not had any problems.
    Tom
  3. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    [Begin Quote] 'Affected' is almost assuredly not the word you want, I suspect 'Effected' would be better. (I know, I know, you are only a journalist, you shouldn't be expected to know English)
    The model year 2004 to 2009 Prius have a recall for floormats, model year 2010 Prius have a recall for braking software. No Prius has a recall for accelerators, as no Prius uses a North American built accelerator pedal. Only Toyotas with an accelerator pedal made in North America are subject to that recall.
    One can learn way more about media frenzy than about automobiles with respect to these recalls.[End Quote]
    You have my permission to quote me in my entirety, no sound bites. - Jimbo Palmer Greenwood MS USA
  4. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Amazing. You just reinforced everyone on the board's opinion of the uninformed press. You might want to check your facts BEFORE you go out looking for evidence. Oh, wait, that would imply actual JOURNALISM.
    Just to educate you, there is an older recall on Generation II (pre-2010) Prius to make sure the floor mat won't slip, and a recall on the Generation III (2010) for a software update related to the brakes. There is NO recall or talk of unintended acceleration on the Prius. Read through the following posts - when you are done there will be a test:
    Should Toyota acknowlege that the braking issue applies to the gen II Priuses?
    Do you think your GEN II has a brake problem.. Please vote..
    Here's what I do about braking issue...
    Prius Brake Problem - CONFIRMED BY TECH
    Brake failure 2005 Prius
    Braking issues in Gen II
    Why no software patch fix for ABS response time in Gen II Prius?
    Toyota sinking faster than the titanic
  5. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
  6. lys
    lys AerodynamicMac
    79
    SouthWest Europe
  7. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    Don't you mean whose? What did you say you did for a living again?
  8. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    Unaffected by the Recall
    Several levels of ownership going on here that's fer sure...
    My Prius is a fine running little car... and I will buy another Toyota, when I need to get a truck.
  9. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    [Begin Quote]What if I am all wet about the word 'Affected' and he REALLY does mean it? Affected - assumed artificially or falsely We certainly have had trolls here who have affected to be Prius owners. (For better or worse, I always assume they are GM employees, Ford seems to be competing by building good products, and I try to pretend that Chrysler already does not exist)
    So yes, journalist who does not capitalize 'I'm', we do have folks here affecting false personas, hoping to spread Fear, Uncertainty and Doubt. Some wish to drag Toyota's reputation down closer to their own, some feel patriotism is belittling other nations rather than supporting your own, some others wish to be victims, hoping someone with deep pockets can be sued.
    I have been driving since 1972, with cars by Ford (5), Chevy (1), Plymouth (1), Jeep (1), Mazda (2), Subaru (1), Nissan (1), and Toyota (2). None was perfect, each had it's quirks.
    In the past, recalls have been very late and subdued, I think Ford had 9000 crashes before they recalled the Pinto. (I owned one) In this new era, Manufacturers are being forced to announce early and loudly. (I think Toyota had 4 crashes) This is causing drama as they are not even allowed time to devise a strategy to fix their cars before announcing they need fixed. (ziptieing your floormats down and 'don't drive your Toyota at all' are the result of forcing the announcement before a fix is ready) We will either get used to the vendor not having a fix at announcement time or they will have to be given more time than Toyota was. I have no prediction which it will be.
    Having Toyota own up to mistakes, (HID headlight issues, Floormat issues, etc.) does not reduce my confidence in the company, rather the reverse. It was somewhat dismaying to see how long it took for Toyota to realize they had an issue with HID headlights, even though it was obvious here on Priuschat. The drama involved in changing the oil change interval from 5,000 to 10,000 miles on the 2010's was all poor communication from Toyota. (some poor owner was drug through quite a lot of disrespect here, because Toyota waffled so bad his story could not be verified for months) Frankness and honesty by Toyota are not causing me any concern for my safety.[End Quote]
  10. Darwood
    Darwood Senior Member
    5,259
    268
    The only effect is that I'm pondering an upgrade to my older Prius, as I think I can get a better deal on a 2010 than I otherwise would have.
    My 05 and 09 have never had a single problem or repair needed.
