After 180,000 miles and almost 8 years of service, I replaced the 12 volt.
Discussion in 'Gen 2 Prius Fuel Economy' started by ozarkretiree, Dec 14, 2014.
  1. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    It was testing okay but my mileage had started to decline from low 40's to mid 30's MPG so I installed the Yellow Top which I had topped off by the dealer the night before. First 2 tanks with the new battery prove how little things (like running the alternator) can significantly change fuel economy. $175 total installed by Battery Warehouse.
    As far as oil consumption, it is almost a non-issue now after switching to Kendall High Mileage 5w-40 five oil changes ago. I am adding about 1/2 quart between oil changes now (5K interval). What a vehicle Toyota gave us!
    Sergiospl likes this.
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    That seems like a logical assumption but it's wrong on two counts:
    A failing 12 V battery can make the DC-DC converter run a bit more (there is no alternator like in a conventional car).
    It can also cause various electrical computer signals to be just a tad bit different, causing all kinds of strange things......including declining mileage.
    Your basic theory is right though as running the AC compressor consumes a fair amount of power and it does make a slight difference in the mileage.
    P.S. You are VERY lucky that the 12 V battery lasted 8 years. With a conventional wet cell, I start getting nervous around 4 years and with an AGM around 6 or 7.
  4. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    Thanks for the correction. I appreciate input from those who know. I am just a nontechnical driver who assumed Prius used a conventional charging system for the 12V. Always good to know the facts and, yes, I know I was lucky.
  5. dolj
    dolj Senior Member
    7,657
    3,874
    Wellington, New Zealand
    Hi Easy,
    Your replies to posters on this subject still confuse me.
    The gentleman said basically that he changed the 12 V battery and now observes that he has an improvement in fuel economy.
    You said the gentleman was wrong on two counts, then you say:
    • A failing 12 V battery can make the DC-DC converter run a bit more;
    • It can also cause ... declining mileage.
    So, apart from the gentleman calling the DC-DC converter an alternator, what exactly was the wrong information?
  6. bisco
    49,500
    great experience o/p, keep it up! they don't make batteries like they used to.
  7. Yakoma
    Yakoma Active Member
    470
    123
    ATL-ish
    Going to go pre-emptive on the 12V after Christmas. 2008 with 83K on it has the original 12V in it, I believe. Haven't tested it except via the on-board diagnostics. Still seems good, but I gotta believe it's very close to death.
    #7 Yakoma, Dec 14, 2014
  8. Easy Rider 2
    1,584
    257
    Ocala, FL
    I thought I covered that.
    The extra load of trying to charge a dying battery is probably not the ONLY thing that causes the lower mileage.
    As a matter of fact, a 12 V battery going bad often will LOOK fully charged when it is not and thus make less load on the charging system not more.
    The mileage difference probably comes more from the computer boards having a slight malfunction because of low voltage.
  9. dolj
    dolj Senior Member
    7,657
    3,874
    That makes sense.
    Thanks.
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Good to hear the factory battery holding up so long.
  11. Patrick Wong
    18,200
    6,474
    It will, if it is not abused via driver error such as leaving a cabin overhead light on. The OPs situation is ideal for 12V battery longevity: ~23K miles logged annually which results in substantial charging time for that battery.
  12. Cadenza
    Cadenza Member
    124
    LALA Land
    To all those in the know -
    After the car sat overnight outside, my 12v battery reads 11.9 - 12.2v depending on how cold it was. With Accessory On, it's 11.5 - 11.8v.
    At what voltage should I replace the 12v battery?
    Thanks!
  13. Easy Rider 2
    1,584
    257
    Ocala, FL
    NOW.
    You start out at 12,.6-12.8 presumably, and just sitting overnight should not drop it much if any.
    That depends a little on how cold it is when the measurement is taken but I think you are right on the verge.
    I start getting nervous at 12.4 no load and 12.0 in ACC.
  14. Sfcyclist
    1,621
    375
    SF, CA
    Since I don't drive 20+k miles annually, I hope to get 7 years out of mine.
  15. dolj
    dolj Senior Member
    7,657
    3,874
    If you don't drive enough to keep the 12 V in good condition, then you just need to get into the regime of monitoring the battery and externally charging as necessary.
  16. Cadenza
    Cadenza Member
    124
    LALA Land
    thanks!
  17. eric29730
    eric29730 Junior Member
    Winchester, Virginia
    2005 Prius, 188,444 miles, 12V battery is 9-1/2 years old but getting weak.
  18. JC91006
    16,482
    8,400
    9.5 years. Wow, I thought 8 years was stretching it for some. You should definitely go shopping NOW.
  19. bisco
    49,500
    you have about the same as my daughter, she has no intention of replacing hers, but it probably won't last more than a few more years. it's not likely close to death, unless someone has run it down.
  20. Yakoma
    470
    123
    ATL-ish
    Yeah...did it last week. Glad I did. Voltage of new battery is a reassuring improvement over what the older was getting. Expect it to go down the road for many years now. As long as she keeps it between the lines, I've done everything that should be done to it at this mileage.
