After 6k miles on my 2011 Prius -- Observations
Discussion in 'Gen 3 Prius Main Forum' started by NewSlow, Jun 8, 2011.
  1. NewSlow
    NewSlow New Member
    Southwest
    The Great: Storage space is phenomenal. Driving around a city environment is excellent and parking is extremely easy.
    The Good: The power is sufficient for fwy driving, even at 7k feet. The stereo isn't bad and the bluetooth is adequate.
    The Bad: Gas mileage isn't even close to 50 MPH. Perhaps if you drive like a stoned grandmother...but if driven like a normal car expect 33 to 37 MPG. Also expect the computer read out to be 7 to 10 miles above what you're really getting.
    The Ugly: I would call this car dangerous to drive on the Freeway. Wind gusts will literally move you sideways...I drive it like I would a motorcycle, leaning (turning) into the wind. Also, it is a loud tin can...with a terrible suspension set-up and terribly uncomfortable seats.
    The Disgusting: Toyota service has been atrocious. The materials in the car are of extremely poor quality and they wear as such.
    Would I buy it again? I think that the car lacks that "fun-driving" factor. I've driven plenty of rentals that have more "presence" than my Prius does. The Prius is rudimentary transportation with presumably good gas mileage and bluetooth.
    If I had to do it again, I would go for the Golf TDI or something along those lines. If the Prius were a 12k dollar car, it would be a great little machine but not at 26k...it is simply not worth the experience.
    Oooops, forgot...It loves to Squeal, Rattle and Complaint and it often won't allow me to lock the car because it thinks that the key is still inside of the car...good times.
    YMMV.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Welcome to PC!
    If you do enough searches here you can find others with similar concerns about Prii. As you get accustomed to how it drives, you will get better mileage and as it breaks in, it will improve. Wait 6 or 7k miles.
    Sorry to hear you have a bad dealership that won't address your concerns.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I'm really surprised by how low your MPG is. Could it be you live in a very mountainous area? I moved from a hilly area (elevation 500 ft) to a flat area, and my mileage increased by a few MPG (lifetime average over 21K miles is 45).
  4. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    I'd say your mpg is a couple of std dev's below the mean.
    You may have very bad facts as to terrain and traffic...
    and/or you may benefit from a clinic on driving for mileage.
    Air up your tires and conserve your momentum.
    Good luck.
  5. DaYooper
    DaYooper Member
    106
    Sout of da UP eh!
    I have yet to get under 45mpg per tank and that was a trip traveling at 80 mpg. I think the mountains are definitely a factor in your mpg. I have yet to see a 7-10 mpg differences between the display and calculated mpg. Max has been ~3 mpg. I think if you live in the mountains, you will have the same problems with the tdi, mpg wise.
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    You either have an extremely short commute, extremely hilly terrain, lots of tightly grouped traffic signals, atrocious driving habits, and/or a combination thereof.
  7. JC Prii
    JC Prii New Member
    31
    Pennsylvania
    not sure how mountainous the southwest is, however, it is hot. But in the 30's? Maybe you should check how you drive...Prius are build to ease into speed, not chirp wheels off the line. Change your driving style and see 50 mpg. The engine is tiny so you have to be gentile and drive with a tomato under your foot for the good gas mileage. I drive my prius like i drove my truck, and im seeing 57 mpg in a quite hilly area.
    As far as wind gusts, they do really shove the car around...it is quite frightening
  8. mlg779
    mlg779 Junior Member
    63
    Buford, GA
    If you show me a picture i might believe-it, otherwise not really.
  9. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    i dont think the prius was built to be a fun car to drive lol
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Agreed w/ksstathead and sipnfuel.
    Here's what CR got in their mileage tests: Most fuel-efficient cars. Also, how are you computing your gas mileage to determine "expect the computer read out to be 7 to 10 miles above what you're really getting"? I know that some/all 3rd gens have a trip computer that's optimistic, but that sounds too high.
    It sounds like your expectations were based upon EPA estimates. Please read http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html for what goes into them.
    Here's what Edmunds got in a comparo: Fuel Sipper Smackdown 2 - Edmunds.com. Unfortunately, the formatting of this page is totally jacked up now.
  11. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Different kind of fun. Seeing the mpg's mine gives me is tremendous fun for me.
    First tank was 58mpg, perhaps more if the dealer hadn't filled it to the top.
    I'm completely happy with mine.
  12. Puddlejumper
    Puddlejumper Junior Member
    17
    Southern Maryland
    Wow! 37 MPG?? I drive my 2011 Prius like I drove my truck, I don't hypermile, and I always use PWR mode, my lifetime average is 49.8 mpg.
    I agree it gets blown around a lot and makes plenty of noises. I think once I install strut tower bars and Eibachs the car will be much more fun to drive.
    Overall I am extremely pleased with the 2011 Prius. I am sorry you are having such bad experiences with yours.
  13. Insight-I Owner
    505
    100
    Essex, CT
    One of the unfortunate and unforeseen results of the EPA estimates is that they have come to be what people expect to get, or worse yet, are guaranteed to get. And then taking it further, they think that how they drive has no effect: they can drive it hard and still get EPA. As the folks at cleanmpg have proven, its quite possible to get well above EPA if you pay attention to mpg - and if you push it too hard you can get well below EPA.
    Basically, mpg depends so much on where and how you drive that comparisons are extremely difficult to make. The EPA tests are well defined but may not reflect your driving conditions or style. Even the relative EPA ranking of two vehicles may not hold true under certain conditions.
    I laughed at the Edmunds test where they said:
    "We obviously didn't follow the same testing procedures as the EPA, so this provides some evidence for our theory that these next-generation hybrids have been tuned specifically to thrive in the EPA test. The others, on the other hand, beat the EPA ratings."
    It could also easily mean that they don't know how to drive hybrids for mpg. Learning the Prius has certainly been challenging for me, very different from getting good mpg in the Subaru it replaces or in my Insight-I (both of which were very different from each other).
  14. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Winter driving plus hills kept my tank average around 40mpg all winter. Constant hills are a killer for this car imo. The OP mentions living at 7k feet so my guess is that he's driving hills a LOT.
    Summer has my averages in the mid to high 40's and I'm happy with that. When I travel to southern new england where it is much flatter I get into the 50's.
    My onboard MPG computer is a consistant 3-5% optimistic (2-3 mpg)
    As for the rest of the OP's complaints... well... I guess he bought the wrong car. {shrug}
  15. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    What mpg did your last car get? Your Prius mpg is probably twice what you got before.
  16. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    Paragraph 1-Agree !00%
    Paragraph 2-Agree, except I have no Blutooth
    Paragraph 3-Nope, I'm 10 mpg higher and I drive aggressively, and the margin of error in my car is give or take 3mpg high.
    Paragraph 4-Handling isn't THAT bad, not great but ok if you pay attention. After "also", I'm in complete agreement.
    Paragraph 5-No dealer complaints, but I agree with the balance.
    Paragraph 6-Would I buy it again, No, but I would never consider any VW, imho they are all junk and VW dealers are even worse than Toyota Dealers.
    Paragraph 7-Nothing like that in my experience with my 2011. oh and I have 5k on mine.:(
  17. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Get your alignment checked. Sometimes, it can come from the dealer out of alignment.
    Expect eco-plastics to not look or feel like "fine Corinthian leather".
    Aggressive driving will lower your MPG, no matter what vehicle you are driving.
    Garbage in = Garbage out.
  18. Mendel Leisk
    38,637
    Well, my wife's been driving our daughter and her kids around off-and-on this week, and the dash display of mileage is currently sitting at 4.5 liters/100km. Assuming that the usual optimistic display, real mileage is likely more like 4.8. That translates to around to, well: 49 miles per US gallon. But our biggest "stone" these days is a beer while watching the Canucks. ;)
    Totally agree, see above. My calc'd mileage is averaging 7~8% lower than what the dash displays. They could do better with this, it's just bull not to.
  19. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    I think its a question of expectations. The Prius is an economy car with a live rear axle, its got a lot of expensive options, but it is an economy car at heart. If you're even concerned about handling...you shouldn't have bought it. Did you test drive it first?!?
    Its perfectly safe to drive on the highway. Does it feel solid and planted in crosswinds? No. Not dangerous though.
    As for mileage, if you are getting 33-37 MPG you either drive hard, have a short commute, or you're lying. We were getting high 30s in our '04 when my wife had a 2 mile commute. Now that her commute is 15 miles, averages are back to 47-50MPG and that is with no hypermiling or attention paid to driving carefully at all. We can take it on a highway trip at 80MPH and get 50MPG. And thats a Gen II...the Gen III has better mileage.
    To the above poster, 7-8% lower and "7-10 miles lower" are pretty different things. If you readout shows 50MPG, 7% is 3.5MPG.
    As much as I really don't care for the car...the mileage is impossible to deny.
  20. Mendel Leisk
    38,637
    Yes, our mileage is off, but not by 7-10/33-77. Still, 7.5% error, consistantly in favour of the "house", is too much.
