After Market Stereo, "Audio Off"
Discussion in 'Gen 2 Prius Audio and Electronics' started by Kevin Alexander, Dec 3, 2017.
  1. Kevin Alexander
    Kevin Alexander New Member
    Ohio
    I've replaced the factory stereo on my '05 Prius with an Alpine stereo, I also used an adapter to allow me to keep steering wheel controls. When I first power on the car, the radio comes on for a moment, then gives an "Audio Off" message and the sound becomes muted. If I turn the car off and quickly back on again, though, the radio works just fine along with all steering wheel controls for the whole drive. Sometimes, instead of going fully muted, the sound simply goes in and out as if someone kept hitting the mute button.
    The fact that the stereo works perfectly on the second on/off of the car leads me to believe everything is connected just fine, but I can think of anything else to check.
    (BTW, simply turning the stereo on and off again doesn't help, and I didn't use the 68 ohm resister mod mention in other threads since I still have climate control and everything else anyway.)
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    Did you do the stealth install below original CD player (single DIN leaving the original CD player in), or did you remove and replace it? Can you be specific about what headunit and adapter kit you used, and any other particulars of how you wired it?
    To me, this sounds like an issue with the aftermarket headunit or the adapter kit (adapter kit may be sending an "audio off" signal to your CD player).
