After recharge how many miles be displayed?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by dcortesi, Sep 16, 2012.
  1. dcortesi
    dcortesi New Member
    After a full recharge the display usually shows 10.9 miles available.
    Checking with a trip odo, this is pretty accurate: in neighborhood driving it'll go that distance, give or take a couple tenths, before reverting to HV mode.
    11 miles seems short, I was expecting a bit more. Is this worth taking up with the dealer?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    how fast are you going? about 40mph? 10.9 is what I get driving 40mph. when I drop down to 35mph my EV goes up to 11.9 I'm currently driving 20mph on side streets to get to work, my trip odo says 14miles, still waiting for the EV range to go beyond 12 miles. Driving 20mph every time I charge my PIP should make go up to 14 tho.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    and I'm on mostly flat terrain too
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    oops, my bad:whistle: my trip odo+EV left over =14 miles
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    curb weight of the PIP is 1435kg
  7. bisco
    49,488
    11.o is the sticker. you're fine. some get more, some get less, based on their driving habits, terrain, climate, etc. just like mpg's. all the best!
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'm up to 12.2 EV whoo hoo!
  9. rockfeller
    rockfeller Junior Member
    88
    CA
    I get 11.4 after recharge, But first few miles goes off fairly quickly(before I drive 1mile). My driving speed is from 25-60 to commute.
  10. stacey
    stacey ☆☆☆☆☆
    115
    23
    Lancaster, PA
    I hover around 12.4 or 12.5 and have seen as low as 11.9 or as high as 13.1 one time. My very short commute to work is kind of up hill both ways (and some downhill) with a bunch of stop signs so still seeing the estimate pretty stable at 12.4 is awesome. If this county were flatter I'm sure I'd see a higher average.
  11. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    New thread on this every week. Take a look back a few pages and you will find a good 200+ posts about this to read through.
    Summary = Your fine. You get about 11. Just as the sticker and all documentation say. 11
  12. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Yeah the new people need to search a page or so we have alot on this subject....
    Mine started at 11.3 range.....and now after some slow EV drives, I got it up to 14.2 after charge. I have been getting 15 miles on my slow trips for about 5 trips, still it wont go higher then 14.2 so far.
    Bottom line OP....drive it slow, and watch your actual miles, you will get over 15.....drive it over 35 or so, and quick starts, go uphill ect ect..and you might only go 10 miles. Its all about your right foot.
    I find if you keep the HSI under 20% in EV you will go ovr 14 miles. Also try to get some decent regen.
    Dan
  13. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Going to the dealer would be a waste of time, IMO. Mine has settled in at 13.1 after a little over 6 months. It is an estimate and based on your driving. It will vary for everyone.
  14. I have charged to 15.2 a couple of times now.
  15. bisco
    49,488
    i was up to 16.5, but due to some excess hv driving i suspect, i'm down to 15.5. but i can still go 17.5, so what else matters?:)
  16. rockerdan
    427
    83
    Wheatfield NY
    Another way to increase the EV estimated range (not that it really matters) is to use EV and HV on n off....How many others do this?
    depending on your drive conditions, Use EV only on those slow urban streets, stop and go type driving, all below 30mph. Switch into HV when you get above 35 or so. Is that that term "stacking" ive read about? Im very new to any hypermiling techniques. I seem to get higher EV ranges after charge the more i only use EV for slow urban streets.
    Dan
  17. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    And there will be for years to come.
    It's just like any other gauge, estimates are only approximations and outcome will vary.
  18. Diddlywop
    Diddlywop New Member
    30
    Irvine, CA
    I have had my plug in since May and the charge mileage keeps going down.....been driving mostly the same route throughout, which is 18 miles each way, with about 15 miles being freeway. Now getting 8.3-8.7 miles to a charge reported.
  19. bisco
    49,488
    exactly.
  20. Sagvca
    Sagvca New Member
    I purchased my Prius Plug-in about 10 weeks ago, in early July. The charge indicator would read 11.8 or 11.6 after charging the battery. After several weeks it registered 11.4 and has gradually declined since that time. The past few days the indicator reads 10.1 after a charge. Might this be a result of the battery not holding the same level of charge after this relatively short period of time or could it be an issue with the charging program or sensor ?
