After releasing gas pedal. I still hear the engine revving up for seconds
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Humailesh, Aug 8, 2015.
  1. Humailesh
    Humailesh Junior Member
    Amman
    I
    After stepping over gas pedal revving up, when I release the gas pedal I can hear the engine revving up some more instead of slowing down.
    When I release the pedal, the engine is still making the noise as if I am stepping on the gas harder for about 3 seconds. when this happened, EV mode will be always not available, and gasoline consumption is increased. Getting lower MPG.
    Can anyone give an advice
    49,474
    it's charging the battery, no worries.
  3. Mendel Leisk
    38,718
    I do not know, that seems odd. I've never noticed anything like that. Get it checked out, maybe have a dealership mechanic go with you on a test drive? Even better would be to also drive a dealership's demonstrator vehicle, for comparison.
    ( back from our road trip btw :))
  4. Humailesh
    Amman
    I
    It is not charging the battery. This happens even if the battery almost full
  5. bisco
    49,474
    whoops! sounds like you'll have to read the codes. do you have a mini vci?
  6. bisco
    49,474
    how many miles on her? maybe the throttle body and mass air flow sensor need a cleaning.
  7. Humailesh
    Amman
    I
    No I don't have it
  8. Humailesh
    Amman
    I
    It has about 117k miles
  9. Humailesh
    Amman
    I
    Recently, I have noticed that this issue comes up during hot days. I assume that there is a relation.
  10. Alesf76
    Alesf76 Member
    89
    33
    Italy
    Sure there is a relation: when you lift the foot from the throttle the car starts braking a bit, simulating the engine braking of a normal car. Under normal conditions it uses regenerative braking. But if the battery is full or too hot it uses engine braking like when you put in B and ICE revs up.
  11. Humailesh
    Amman
    I
    Do you mean this is normal ?
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The rev hang you describe happens when the battery ECU is protecting the battery when it's too hot. I notice this when my battery temps are somewhere above 46°C/115°F. You get very little hybrid assist, no regeneration, engine rev hang, and persistent idling.
    The engine slowly revs down instead of being quickly spun down through generation. It is using fuel during this process. The advantage here, is that power is almost instantly available if you need to accelerate again, vs the slow and painful wait for the engine to spool up again in this mode.
    I'm on my 7th summer in my 2010, and the past 2 summers have been the worst for this. I'm actually quite frustrated by the phenomenon, despite understanding why the ECU is protecting the battery.
  13. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    Before the summer I got an update that causes similar behaviour. When I rev the engine it slowly turns off. If I keep pressing the gas pedal but keep in the EV part it turns off even slower. I would guess it's to lower the number of start/stop cycles of the gas engine.
