Aftermaket Halogen Lightbulbs
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Sunfire4jc, Sep 1, 2006.
  1. Sunfire4jc
    Sunfire4jc New Member
    32
    Hello,
    I wanted to install some Silverstars or some Halo aftermarket light bulbs for my headlights, but when i went to different car mechanics and the toyota dealer (Longo), they all recommended against it
    Halo automotive - http://www.haloautomotive.com/products.asp
    They claim that It may cause damage, and the repairs would void the extended warranty. They further claim that it draws too much power and that these light bulbs do not last long
    Can anyone feedback on whether or not I should go ahead and do this mod, or should i just not risk it.
    OH BTW...what size is thte headlight bulb? The Manual says HB2 for a 2006 prius, but I dont know what bulb i should get. I appreciate the comments. Thanks
  2. Trollbait
    11,563
    I don't see how they could cause damage or void the warranty. However, CR had a report awhile back on the brighter aftermarket bulbs. On average they weren't any better than the standard ones.
    As has come up in the LED threads, the reflector was designed around the standard bulb. The brighter aftermarket one could be physically brighter, but with its size and shape, you could end up with less light reflected onto the road.
    Personnally, I'd wait until the bulbs go before considering trying something new.
  3. Tideland Prius
    16,157
    I have Silverstars on mine. They're almost a year old (put them on last October-ish). On a dark road with no lampposts, you can see that they're much whiter. In terms of brightness, I'm not sure cause it could very well be the fact that it's white that makes it seem brighter. I do think they are (especially last November when we had dense fog for a week or two). Again, it doesn't help in the denser areas of fog since it'll reflect more light but on the whole, I'm fairly satisfied with it. I have heard of them burning out early but since there's a one-year warranty on them, I'd save the receipt just in case. Remember to never touch the bulb.
    The size is 9003.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    we have SilverStars in both Prius and wouldn't want to be without them now that we have two winters on them. Standard halogens now seem like candles. I'll agree with Tideland about the extra light during that fog session last winter.
  5. Conine
    Conine New Member
    70
    how did you put them in?? did you remove the entire headlight or just work your fingers in and around til you got it?
  6. Tideland Prius
    16,157
    <div class='quotetop'>QUOTE(Conine @ Feb 13 2007, 05:19 PM) [snapback]389876[/snapback]</div>
    You access them behind the headlight. The Prius' system is a bit of a PITA.
    you have to unplug the module, then remove this rubber neck/cover before finally reaching the spring-loaded catch that holds the bulb in place.
    Removing everything isn't an issue. Putting back that rubber piece is time consuming.
    For the record, my dad's Camry uses 9006 bulbs for the headlight and it was a breeze to replace.
  7. Conine
    Conine New Member
    70
    yeah i cant fit my hands behind there, they are too big any other ways to do it?
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 13 2007, 05:39 PM) [snapback]389890[/snapback]</div>
    "The Prius' system is a bit of a PITA."
    That is putting it mildly!
    He failed to mention that you have to do everything by feel. You cannot see what you are working on without a mirror and then everything is backwards.
    I have replaced both of mine as they burned out(30 and 35,000 miles) with the regular unit but will probably change to SilverStars when the next one burns out.
  9. Conine
    Conine New Member
    70
    yeah i noticed it was all by feel, lol i tired to take out the right one today at work and broke 4 of the clips holding the black plastic in place! so im taking it as there is no way to remove the entire headlight? and i noticed that there was a mayonnaise like cream inside the plug. is that normal??
  10. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Conine @ Feb 13 2007, 06:47 PM) [snapback]389933[/snapback]</div>
    On the RH side of the car you get fairly easy access by taking off the snorkel for the air intake, that is mentioned in the owners manual the LH side is the difficult one. The rubber rings turn off the back of the assy. and yes there is grease in the socket that plugs onto the bulb. It's a bit of a struggle but to take out the H/L assy requires removal of the front bumper and all associated parts. A little patience or the neighbours or you kids small hands will help your H/L project.
    Edit: the secret to the black plugs that hold the air deflection panel on is to push the pin in the middle in about 3/16" with a pencil or small screw driver or even a key, then pull them up and out of the panel.
  11. Conine
    Conine New Member
    70
    cool thanks for the info i will see if i can get this done sometime tomm, but i doubt it, because ive always had problems with headlights :(
  12. c4
    c4 Active Member
    607
    51
    I looked up the bulb data from the sylvania site and the Silverstar lifetimes for a 9003 bulb are 150 hours on the low beam filament and 50 hours on the high beam compared to 800/150 hours for a regular halogen lamp, so you definitely are sacrificing bulb life..
    I've got the XtraVision bulbs, which are apparently equivalent to the European Silverstars (no blue tint) in my car and they are noticably brighter and whiter than standard halogens. I cannot stand the blue tinted bulbs though; I have night contrast issues, and blue at night just causes glare to me and these bulbs simply do *not* look "whiter" to my eyes, in fact, oncoming vehicles with blue-tinted bulbs have a distinct "baby blue" or cyan halo around them and they look nothing like HID bulbs which I have no problems with- HIDs are very "white" with a slight purplish-blue fringe.. This is quite different than tinting the light blue all over.. I think the effect is more pyschological than real, especially as science tells us that our eyes are much less sensitive to blue, and the blue gets scattered more readily (ie, that's why the sky is blue)..
  13. Frank Hudon
    4,147
    mine have 3 years of DRL's and night time useage and some hi beam without problems 3 years in her car as well and still on the origionals in both. I do know that Tideland Prius has had some burn out but "cross fingers" ours are still working fine. I agree with C4 that the blue tint are just annoying.
  14. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    It may be possible to undo a couple of the headlight unit and quarter-
    panel bolts and get a little more maneuvering room by pushing things
    aside that extra half-inch. I've managed to access the back of both
    lights without it just for proof of concept and to figure out which
    way those little spring retainers are pointing, and it *is* a PITA.
    At one of the training weekends some of the techs loosened up the
    nosepiece of another '04 enough to actually remove the entire
    headlight unit -- apparently there are several tricks applicable to
    many newer cars, but unfortunately I didn't watch closely enough to
    remember exactly how they did it. But maybe when the weather warms
    up, an investigation and resulting web-page will be in order...
    _H*
  15. Frank Hudon
    4,147
    I just put them in, it was no real big deal. There are a lot worse things to get to than the bulbs in a Prius. Doubt that I spent all of 10 minutes re and re'n the h/l bulbs in either car.
  16. Tideland Prius
    16,157
    Yeah, I had my Silverstars blow (both of them) ~ a month or so after I made that post up there in Sept.
  17. c4
    c4 Active Member
    607
    51
    Hobbit- on a semi-related issue- do you know if there's an easy way to remove the entire headlight units or at least get them out of the vehicle sufficiently to pop the latches on the transparent lens? (I can pop the ones on top, but can't get to the ones hidden on the sides/bottom)..
    The reason for this is that my car is now 7 years old and the headlights are now rather rough on the outside and on the inside: 7 years of condensation and moisture have left a film on the inside of the lens and on the reflector surfaces so I'd love to be able to clean the inside and then buff the stone dings and scratches off the outside.. I know that in the winter, just the dirt and salt film accumulating on the lens will dramatically reduce the headlight output, so I'm sure that cleaning the lens and reflector will restore that much more light output.. Unfortunately, the only way I can see of getting the headlight units out is by first removing the front bumper assembly..
  18. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(c4 @ Feb 15 2007, 06:36 AM) [snapback]390807[/snapback]</div>
    on the Classic and the G2 you have to pull the front bumper cover. It's really not a big job a bunch of screws and pop the latches and it falls off. That gives you access to the lower mounting bolts for the H/L assy.
    Edit: I use a product called GT88 on clean soft cloths to polish the lens and it makes a big difference. I don't think you can get the lens off, I think it's sealed with acrylic sealant.
  19. c4
    c4 Active Member
    607
    51
    The clear lens just looks like it is held on by a bunch of plastic latches- I've looked fairly closely at the front edge and there doesn't seem to be any sealant or anything else there, but even if it is glued on, at the very least, if I could get the unit out, I could remove the bulbs and insert a stick or something with a swab at the end through the bulb holes and wipe off the inside of the lens that way..
    As for cleaning the outside, I've already polished it as best I could with a number of plastic polishing compounds and even a felt bob and compound on a pneumatic die grinder, but again, after 7 years of stone and dust impact, the lens is pretty bad, and I really need to get it on the big bench buffer to really get it really clear and shining.. Loctite sells a headlight kit with several grades of sandpaper and a bottle of polish, which I suppose would also work, but having tried this before, it's a *LOT* of work to do by hand..
  20. Frank Hudon
    4,147
    forget the Locktite stuff I used it when it first came out and that is for people who don't have a life of any kind and need a hobby. You could tape off the fenders and bumper and attack it with a 7" polisher and glazeing compound. But if you've never done serious polishing before be warned that you can do more damage than you ever thought possible in less time than you'd ever think possible! I watched a guy polish a hole thru a Ford Tarus h/l lense.
