Aftermarket 16" rims
Discussion in 'Prius v Accessories and Modifications' started by Weirderal, Jul 12, 2024.
  1. Weirderal
    Weirderal Junior Member
    51
    Pennsylvania, United States
    Hey all,
    In the course of the mods I'm doing for fun on my 2012 v Three, but still trying to keep the good fuel economy, I'm considering getting some aftermarket rims. The trick is, I want to stick with the OEM tire size--I'm only 30,000 miles into the 80,000-mile warranty on my Hankook Kinergy PTs.
    I have the 16" tires.
    2012 Toyota Prius v - Wheel & Tire Sizes, PCD, Offset and Rims specs | Wheel-Size.com
    This website lists the spec as 6.5" wide, 5x114.3 bolt pattern, 60.1mm hub bore, and 37-41mm offset.
    I was hoping for colorful rims, but 16" x 6.5" seems to be very hard to find.
    The closest thing I've found so far is these:
    https://www.customwheeloffset.com/buy-wheel-offset/RTX-081837/rtx-envy-16x65-38?vehicle_type=Car&year=2012&make=Toyota&model=Prius+V&trim=Three&drive=FWD&modification=No+Modification&rubbing=No+rubbing+or+scrubbing&suspension=Stock
    They match in all specs except hub bore, which they have as 73mm. But that can be remedied with wheel hub centric rings (or so I am told by the Autopian Discord).
    Anyway, I was curious if anyone else had done such a mod, or knew specific websites selling other colors. I was hoping to find blue or orange options or something, but everything else I can find is 16" x 7".
    Thanks in advance.
  2. Tombukt2
    Tombukt2 Senior Member
    13,484
    2,425
    Durham NC
    I've done it plenty in similar cars like Corollas some Hondas other Toyota models that didn't come to this country It's pretty basic stuff I can't answer for your Prius v version 3 or whatever we got here but pretty much all the same stuff so shouldn't be a real issue there should be plenty of wheels in even 16 in It was an expensive wheel and tire size at the time but I would imagine now shouldn't be a real problem as tire manufacturers and wheel manufacturers will pretty much whip up anything depends on how nice the wheels you're talking about I think this is where a lot of the problems will come in the people looking for 16-in wheels generally are prepared to pay the nice car kind of money It's a size not a lot of people come looking for It's too easy to flop back to 15's no matter what tire you just bought I mean the car people that would be kind of not really relevant The gas mileage and the inexpense of a lot of tires and whatnot in the 15-in common is butter tire size in the US for a hundred years well it's hard to mess with that
