Aftermarket AC charger?
Discussion in 'Prius c Technical Discussion' started by Boatycall, Jan 8, 2013.
  1. Boatycall
    Boatycall Junior Member
    37
    Tacoma, WA
    My MPG in the morning is horrible, mainly because of my drive home the night before. I'm looking for an aftermarket charger to top off the batteries overnight.
    When I drive home at night, I have to go down a couple miles of 25mph residential streets. So of course, it wants to run on EV as much as possible. I sometimes do the punch-it/coast routine to run the ICE and keep the battery up, but I'd rather not continue to do that.
    So after driving home the night before, in the morning, the battery is down to two lines. I've seen my starting/cold MPG as low as 9mpg (yes, 9) as it tries to warm up and charge up all at the same time.
    I'd like to come home, plug in, and charge back up. Not trying to run long distances on EV, just improve the morning warm up MPG.
    49,488
    there's a really good one, but it's expensive. it's called a pip!:p
  3. clgutierrez
    clgutierrez Junior Member
    51
    17
    I assume the 9 mpg lasts a couple of minutes (during the warm up) going better after 5 min and up to the infamous 50 after 10-15 min. I would recommend to arrive at home with 4-5 bars.
    Sent ?
  4. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Not too sure if Enginer | Solar Powered Prius Plug-in PHEV Conversion Kit with Lithium-Ion | Hybrid are still operating, but you could get a DC converter from them (think it's about $500) and a power supply (48V, 80A) and you have a mains charger for the HV pack. Going from two bars to seven (I'd avoid going to eight) would only take around five minutes, you just need to sit in the car with it in Ready and watch the bars. After it's charged, turn off and unplug. Alternatively, get a 48V, 40A power supply and down dial the output of the converter, it now takes about ten minutes to get to 7 bars.
    Although honestly you could use anything with a DC output above 230V, and 14 amps or less. The key is sitting with the car in Ready and watching the bars, you can't do this with the car shut down it's just too dangerous.
  5. Flaninacupboard
    1,297
    213
    Midlands - UK
    Actually, this would do the job nicely:
    EV-Power | Charger for LiFe(Y)PO4 - 240V/5A - 1.5 kW TCCH-H292-5
    The output voltage is right, and aperage is 5A, you'd have roughly a 15 minute wait to go to 7 bars, and you could set the output of the charger to be at the right level for charging to level off at 7 bars (so you could leave it unattended)
    Alternatively this gets you charged ~7.5 minutes, but is significantly more expensive!!:
    EV-Power | Charger for LiFe(Y)PO4 - 240V/10A - 3 kW TCCH-H292-10
  6. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    You could also get the engine block heater and greatly improve your cold weather engine performance. It's simultaneously the cheapest and most effective mod you can make to increase gas mileage and engine life.
