Aftermarket Catalytic converters that work (links only)
Discussion in 'Gen 3 Prius Main Forum' started by Ds001001, Oct 18, 2022.
  1. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    https://www.ebay.com/itm/303890171766
    This Canadian made one slid into the pipe where it was cut between the cat and heat exchanger.
    This, in combo with Denso downstream o2 sensor, resulted in no codes after clearing them and doing multiple start up cycles. Car isn’t registered yet, so don’t know yet after long drive.
    Thread started to have a single location for working after market cats listed.
  2. Tombukt2
    Tombukt2 Senior Member
    13,444
    2,418
    Durham NC
    That's what I'm talking about.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Easy peasy, Just put a cat converter shield over a non carb complainant cat and you’ll pass visual inspections.
