Aftermarket GPS in sunglasses holder?
Discussion in 'Gen 3 Prius Audio and Electronics' started by fuzzy1, Nov 9, 2009.
  1. fuzzy1
    10,254
    Has anyone tried to modify the overhead sunglasses holder to hold an aftermarket GPS? If so, was it successful?
    Someone mentioned this possibility long ago, and I couldn't relocate the thread. This looks like a nice idea to keep it readily available, yet easily and completely hidden when leaving the car. But it would require cutting, at least to remove the nosepiece molding, and possibly drilling to run the power cord. I've already determined that the body of a 4.3"-display unit should fit, but its bracket and power cord entry could botch the whole thing. And signal reception is uncertain.
    Before cutting, and possibly learning that a clean looking solution may not be possible, I want to hear of anyone else's solutions or experience..
  2. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    it can get real hot up there
  3. patsparks
    10,664
    567
    Adelaide South Australia
    I found that when it is open the sunglass holder can block part of the mirror. I also find it too close to see without refocusing.
  4. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    I'd be concerned about signal reception too. Try plugging in the GPS and holding it up there temporarily (zip ties, etc) and drive around and see if you can get signal. I'd love a flip down GPS :)
