Aftermarket Head Unit Questions
Discussion in 'Gen 4 Prius Audio and Electronics' started by gbugler, Nov 30, 2018.
  1. gbugler
    gbugler Junior Member
    Hello Prius Chat community. I have a 2016 Prius 4 (No JBL with Navi) and I am going to replace the head unit with the Pioneer AVIC-W8400NEX with a Maestro RR and all the recommended harnesses. I have already replaced all the speakers in the car. I have a couple of questions.
    Where did you mount the new microphone that came with then head unit? I would like to mount it were it cannot be seen. Was anyone able to mount the new mic where the old factory mic was?
    Also, can the new head unit use the existing GPS antenna? I know there is a harness connector for the factory radio antenna, but not sure if this also includes the GPS antenna? Also, would like to keep that out of sight if I have to use the new head unit antenna.
    Thanks in advanced.
  2. Leadfoot J. McCoalroller
    8,145
    7,645
    Pennsylvania
    2018 Prius c
    Not sure how many differences there are between my c and your regular prius, but given that I used references for a Tacoma truck I don't think it's going to be that different...
    Anyway... I removed the stock microphone pod from the ceiling, gutted the assembly, installed the aftermarket mic in the shell of the factory unit and then reinstalled it in the ceiling- it looks original.
    Then I trimmed the mic wires out of the harness behind the dash and spliced them onto the aftermarket mic plug, and plugged it into the back of the new head unit.
    In other words, I'm using the factory mic mount and trim and wiring, I just replaced what was on each end of the wire.
    Recycling the gps antenna is possible, but that would be really hard to prove and plan in advance. You should plan on that session being open-ended for timing and results since it may take a few tries with different cable adapters.
    That said, lots of aftermarket GPS antennas work fine when you just glue them to the underside of the plastic dashboard. GPS signals will have no problem coming through the windshield glass and dashboard plastic.
    Ben Vaughan and gbugler like this.
  3. jerryxsara
    jerryxsara Junior Member
    31
    Taiwan
    My 2016 Prius w/ Nav and JBL, I replaced my stock radio with W4400NEX and using GPS adapter(ACC-SAT-TO2) to retain the shark fin antenna.
    This GPS antenna adapter package has 3 different type of adapters, Pioneer, Alpine and Kenwood will be supported, there’re more but not so sure what brands. For my case it works.
    gbugler likes this.
  4. timothevs
    timothevs Junior Member
    Tampa
    2019 Prius
    I just did a 4400NEX install in my '18 Prius Three the last weekend.
    I mounted my microphone right between the two visors, to the side of the mirror. It is an amazing improvement over the stock mic (not even sure where that was). The other party can hear me crystal clear during calls, etc. It simply works wonderfully.
    Unfortunately, I didn't have much luck with reusing the existing GPS antenna. I used the ACC-SAT-TO2, and I thought I had it all connected properly, only to find out during my test drive that the Antenna status shows "NOK". Using the phone GPS with Carplay has been quite a disappointing endeavor. I can't wait till this weekend to try and fix this. If it means I need to use the Pioneer GPS unit, well, it won't be the end of the world - as I've heard it is better than the stock GPS unit. :/ I really want to avoid that scenario.
  5. gbugler
    I completed my install of a AVIC-W8400NEX in my 2016 Prius Four w/ Nav and no JBL and I was able to use the factory antennas for the GPS, HD radio and the SXM radio using the ACC-SAT-TO2 kit, all seem to work well. I mounted the new mic just left of the center mirror hanging off of the head liner. I also left the Maestro RR USB cable plugged in and hanging in the glovebox so I can re-flash if needed (which I have done already. I disconnected the battery from the car and then re-flash the RR.) I was concerned that the RR had a limited to how many times you could flash it but I called Idatalink support and they confirmed there is not a flash limit. Steering wheel controls all work. One issue I have with the steering wheel controls is I have programed Up/Down button to track/preset with one press and seek with long press. This works fine with radio and XM but in CarPlay a single press does nothing when listening to Apple Music, but a long press advances the track and a longer press seeks through the song. A single press should advance the track but it does not?
    Thanks everyone.
  6. timothevs
    Tampa
    2019 Prius
    I found out why my GPS isn't working. Such.a.dolt. :/ Sorry.
    Glad you got it all figured out - not sure about your question though. I haven't messed with mine too much yet.
  7. chriscarlo
    chriscarlo Junior Member
    Panorama City
    Hi JerryxSara, do you mind posting a list of your install. I also have a 2016 Prius 4 w/ Nav and JBL... looking to replace my stock radio. I just wanted to know what works and what didn't work on your install. Thanks for your help in advance.
  8. jerryxsara
    31
    Taiwan
    My installation list as below,
    Pioneer W4400NEX
    Maestro Rr
    ACC-SAT-T02 GPS adapter
    ADS-HRN-RR-T02
    Metra 95-8264HG dash kit
    TOYOTA USB adapter(I bought this in Taiwan)
    TOYOTA Antenna adapter(I bought this in Taiwan)
    Vyse likes this.
  9. chriscarlo
    Panorama City
    thanks for the list does this list makes everything work on 2016 Prius 4 Nav with JBL?
  10. jerryxsara
    31
    Taiwan
    Yes, my Prius has JBL and Nav, the GPS antenna can be adapted.
  11. MichalGocl1981
    MichalGocl1981 Junior Member
    Austria
    Hello Jerry, did you replace the factory Bluetooth microphone, or can you keep it via maestro RR? Kind regards from Austria.
    iPhone ?
  12. jerryxsara
    31
    Taiwan
    Hi MichalGocl1981,
    I didn’t replace the microphone and I’m using the one came with the head unit, just use a double-side tape to attach the mic, I knew some people route the head unit mic to the location where the factory mic is.
    My friend told me that the new mic provides clearer sound than the factory mic.
  13. Al Ortiz
    Al Ortiz New Member
    2019 Prius
    Hi JerryxSara,
    Can you detail what car functions you lost ( hybrid monitoring, maintenance info, door/window settings, etc)?
    Thx
  14. jerryxsara
    31
    Taiwan
    The hybrid monitoring won’t display on the head unit but still display on the cluster, the maintenance should be able to show on the cluster but I’m not so sure. The only thing will lost is the compass and turn by turn nav if your car equipped with nav.
    D/W setting can be supported by Maestro RR and access it from the head unit.
  15. Radd1280
    Radd1280 Junior Member
    Bensenville
    2019 Prius
    Hi Jerry @jerryxsara -
    Would you mind posting a picture showing us where/how you mounted the microphone? thanks!
    QUOTE="jerryxsara, post: 2879080, member: 168600"]Hi MichalGocl1981,
    My friend told me that the new mic provides clearer sound than the factory mic.[/QUOTE]
    Ben Vaughan likes this.
