Aftermarket HID? Results?
Discussion in 'Gen 2 Prius Main Forum' started by invertalon, Mar 20, 2008.
  1. invertalon
    invertalon New Member
    Ohio
    Hey guys,
    Dad just bought a new 2008 Prius today and was interested in having me install a HID kit. He wanted the HID package, but did not want to spend all the extra money for what he was getting for the package that had it.
    I currently own a 2008 Scion xB in which I have placed in a MobileHID kit into (amazing dealer, kits are top notch), however, mine has projector housings and the prius does not. Has any of you done a conversion using the stock reflector housings and how has the glare been? I expect some yes, but just want to hear first hand how it is.
    Thanks for the help!
  2. Rich96c4ce
    Rich96c4ce New Member
    55
    Southern Maryland
    Headlamps that have optics designed for halogen filament bulbs can not be fitted with HID bulbs and be expected to comply with federal and state motor vehicle beam pattern and intensity requirements. Anyone who says otherwise is a snake oil salesman. What your are getting yourself into is a headlamp system that has way too much intensity in the wrong places on the highway. That not only is bad for you, but also for other highway users. Also, if your headlamp emits both the lower and upper beams from the same reflector/bulb, then you are most likely to loose having an upper beam. Some aftermarket kluges use solenoids or motors to move the HID bulb around in the headlamp socket to make up for that deficiency, but most are unreliable, all compromise headlamp performance, and all achieve undue glare.
    Bottom line: if you want real HID headlamps, get OEM HID headlamps when you buy your car.
  3. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    If you just put in a new bulb, it'll be lousy. You have to swap the housing too. There are usually Pri on eBay that have been in a rollover or something. You could probably find someone to sell you the housings, bulbs, and starter (starters?) as a package. The HIDs are nice.
  4. Rich96c4ce
    55
    Southern Maryland
    You are so right! But for most prospective Prius purchasers, the best advice is to test drive both kinds of headlamps at night! The buy the kind that you want when you order or pick out you new Prius. It will save lots of headaches and guilty feelings.
  5. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    the cutoff on the halogen lamps are just as good as the HID housing, im not promoting it, but the HID housing and the normal halogen housing are almost the same, the bulbs are located in the same area, except the HID has a auto leveling system.
    i would buy a kit if i had the money, the stock halogens are great though, i would just stick with it.
  6. Rich96c4ce
    55
    Southern Maryland
    Regardless of what anyone may tell you, I reiterate: "Headlamps that have optics designed for halogen filament bulbs can not be fitted with HID bulbs and be expected to comply with federal and state motor vehicle beam pattern and intensity requirements. Anyone who says otherwise is a snake oil salesman. What your are getting yourself into is a headlamp system that has way too much intensity in the wrong places on the highway. That not only is bad for you, but also for other highway users. Also, if your headlamp emits both the lower and upper beams from the same reflector/bulb, then you are most likely to loose having an upper beam. Some aftermarket kluges use solenoids or motors to move the HID bulb around in the headlamp socket to make up for that deficiency, but most are unreliable, all compromise headlamp performance, and all achieve undue glare.
    Bottom line: if you want real HID headlamps, get OEM HID headlamps when you buy your car."
    If you do not trust me, click on my name and read about me.
    2 people like this.
  7. snapster
    snapster New Member
    Hmm- how appropriate. lol. I'm looking for a 2g prius with HID and came across this thread. I agree with Rich with the fact that they are ILLEGAL. However, there are A LOT of things that most of us do that are illegal when we drive. Speed, change lanes w/o signaling, lift our trucks to make the light output at a given height go beyond the maximum tolerance allowed to prevent blinding other drivers, etc...
    That's not to excuse the fact that the lights are illegal and I won't chide you if you do something illegal because we're all grown up here and we can all make decisions on our own. What I will say though is - if you're going to add an HID kit, add the right kind. I took at look at the lights offered by the company in the original post and the HID H4 bulbs that they use will offer you your high beam option (albeit, a halogen bulb) but it will still have one.
    I am looking for a used prius like the OP's dad and would love to get one with factory HID but if I can't find a good deal on one with them, then I'll have to settle for one without. I have aftermarket HID lights on my car right now that I bought years ago when Philips used legitimately make sets and they work wonders. What I did notice compared to a factory HID is that the way the housing is designed, it projects more light directly in front of you because it is designed for a halogen which does not have a lot of overall light output. After putting in the HID bulbs, I noticed a lot more light directly ahead of me on the ground compared to other cars that were the same as mine but that came with HID from the factory. I'm not saying this is good or bad, it just is what it is - but I can definitely see better at night and I don't get flashed at all.
