Aftermarket led daytime running light problem
Discussion in 'Gen 2 Prius Accessories & Modifications' started by wllee203, Aug 16, 2015.
  1. wllee203
    wllee203 New Member
    Hong kong
    Hi all,
    I am now install a Led DRL for my prius 2 and the power is connect to 12v poistive point, so my DRL can switch on when start the engine。
    But i found a problem today,when i stop the car for around 5mintues,the DRL will switch off and light up again when moving。
    So is that mean the 12v power will turn off if the car stop after few minutes?
    Or should i change to connect other fuse ?
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Which LED DRL did you install? If it's the Philips daylight 4 or 8, then you can email them. They have a module they can send you that will take care of the problem.
