Aftermarket Nav
Discussion in 'Gen 3 Prius Audio and Electronics' started by kev12345, May 26, 2010.
  1. kev12345
    kev12345 Junior Member
    68
    24
    Vancouver, BC
    Aftermarket Nav w/ Cam
    I'm looking at getting the new Pioneer AVIC X920BT receiver as I hear the toyota nav is garbage.
    I don't care for the camera image in my rear view mirror, and would like to instead see it on the new head unit. Am i going to have the proper connections behind the stock unit to make this happen?
  2. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Yes, it has an input for a rear-view camera, but I do not know if you will be able to use your existing rear view camera with it.
  3. kev12345
    68
    24
    Vancouver, BC
    I know the head unit has an input for the camera, but i was wondering if the wire is actually back there since right now its displayed way up in the rear view mirror. i was just wondering if it would be plug and play or if I have to splice the connection in the mirror down to the head unit area.
  4. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Re: Aftermarket Nav w/ Cam
    You *should* have a composite video cable someplace - but will have to locate it (follow the wires?).
    Read the threads - you have JBL, and will likely need a thing from PAc called the PAC-TATO ($70). You will also need the PAC-SWI PS ($40), and possibly PAC WRI ($40 + $25 remote - if you want to add a wireless remote - see that thread here later)...
    With all that, there's no reason it would not work... You may consider the Z110 for it's larger display - but that's preference.
