Aftermarket plug-in heated seat pad
Discussion in 'Gen 2 Prius Main Forum' started by jimmyrose, Aug 8, 2006.
  1. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    When we were car searching, one of the things my wife REALLY wanted was heated seats. But, she doesn't care for leather seats (which I think may be the only ones that come heated, on just about any car). Has anyone ever tried the aftermarket pads that plug into the 12V power outlet on a cloth seat Prius? I imagine mpg will suffer slightly from the addional electrical draw and subsequent recharge cycling of the ICE, but any other negatives I should be concerned about?
    The things I'm willing to do for my wife's butt.... :rolleyes:
  2. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(ZenCruiser @ Aug 8 2006, 08:04 AM) [snapback]299547[/snapback]</div>
    I have installed aftermarket heated seats and leather interior. The company was called ASC (914)633-1550 Ask for Tony and tell him BobZ sent ya ;)
  3. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    You'll want to be careful with any sort of pad that plugs into the outlet in the car. Remember, those outlets are fused at 15A (for both of them). i only mention this cause heating units of any type are historically power hungry beasts that require a lot of current.
  5. onerpm
    onerpm New Member
    477
    MN
    yeah! My 2005 has the cloth fabric, and last fall I picked up a heated seat pad at Fleet Farm. I think it was on sale for $20 or $25. It's great! Black, doesn't look bad. I took it off for the summer. Has a couple stretchy bands that you click together underneath the seat (that was bit of a challenge on the second one, closer to the center console), and a couple that go around the seat back. It stays in place pretty well. I used it a lot last winter, as I live in Minnesota. No problem with fuses or anything like that. I believe the pad has its own fuse too.
    The cigarette lighter plug easily reaches into the center console, and it has a separate control, with High and Low settings. Heats up fast, actually faster than my wife's former Accord that had factory heat (probably because the heat is just going through fabric instead of leather). I'd recommend it highly. I will find the receipt tonight and post the brand and website, if any, tomorrow on this thread.
    Now my wife just picked up a 2006 Prius last week that has the leather package. She won't go for the aftermarket pad, no, no, I've gotta get seat heaters professionally installed for her. It's about $250/seat, and two installers told me they might not be able to put in the butt heater on the passenger seat (but they can put the element in for your back) because of the airbag passenger sensor. Won't know for sure until they have leather off.
  6. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    Thanks for the input everyone... luckily, I've got a couple of months to make a decision which way to go.
  7. onerpm
    onerpm New Member
    477
    MN
    Zen, I found my stuff on the heated seat cushion that I bought for my 05 Prius, and like a lot:
    1. Brand is Tranquil Ease, made by Raffel Comfort Science, LLC out of Saukville, WI. The instruction brochures lists a website of www.raffel.com; an one-sheeter glossy advertisement that came with it, promoting the seat heater as well as travel pillows, etc. lists a website called www.tranquilease.com.
    2. My notes show I bought it (at a regional store in MN called Fleet Farm) on sale for $16.95, and that it was sold online for $24.95. That was probably on the tranquilease.com site, because that's where I registered it for the 6 month warranty.
    3. The glossy ad listed a promotion code of LC10 that is supposed to give you 10% off your next order. No expiration date listed, so you might try that.
    It gets pretty hot...I usually start off with it on High, but can't leave it there for very long without kicking it down to Low.
    Rob
    and, by the way, I am pretty sure that you can have aftermarket heat added to your cloth seats; you don't have to go to leather. About $250/seat.
  8. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(onerpm @ Aug 9 2006, 05:39 PM) [snapback]300424[/snapback]</div>
    If you have side air bags, make sure those straps won't interfere with the airbags functioning properly.
  9. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    <div class='quotetop'>QUOTE(onerpm @ Aug 10 2006, 12:15 PM) [snapback]300852[/snapback]</div>
    So, what you're saying is you don't have much information on it.. :blink:
    Wow, thanks so much for all the great detailed info...I'll definitely check this out as well as adding the aftermarket heat. My wife's pretty frugal, so if the plug-in's 10% of the cost of an aftermarket seat, built-in heater I'm pretty sure she'll go cheaper...
