Aftermarket rims for C Two
Discussion in 'Prius c Accessories and Modifications' started by Daniel Grevillius, May 28, 2014.
  1. Daniel Grevillius
    Daniel Grevillius New Member
    Newport News, VA
    I am looking to swap out my Steel wheels and hub caps for actual rims. Ideally, I will use the same tires that are on the car now. What are the exact specs of the existing rims? I know they are 15", but offset and lugnut configuration?
    Also does anyone have any aftermarket rim suggestions???
    Thanks!
  2. Spock
    Spock Junior Member
    72
    34
    Pasadena, Ca
    2014 Prius c
    stock wheels are I believe 15x5, 4x100 configuration. Offset - about 40mm. 15x6.5 wheels would probably be ideal on the stock tires but I've heard of people stretching it to 15x7, keeping more or less the same offset.
    At this size you really have a lot of options as far as keeping the car performance. Any alloy rim will be lighter than the stock, although not as aerodynamic. The stock steal rims are in the 15.5-16 pound range. try going on tirerack.com they have tons of options.
