Aftermarket sunroof on 2007 prius
Discussion in 'Gen 2 Prius Main Forum' started by tylerjames, Oct 5, 2017.
  1. tylerjames
    tylerjames Junior Member
    26
    north bay
    Hi all, I bought my Prius 2 years ago used. It came with a aftermarket sunroof. Lately it has been moving slow, and just the other day died completely (luckily it is fully shut, but won't open)
    Any idea where the fuse would be? Or how to check it before ruling it broken? Thx
  2. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Motor most likely died. If the DC motor contains replaceable carbon brushes, maybe just the brushes need to be replaced?
    Try looking at the 12V battery post. Do you see anything that is clearly not factory, connected there/nearby? If everything looks stock, installer made a 12V+ connection elsewhere. Find it.
    Ask the owner who had the moonroof installed, who did the installation. Then ask the person/shop, where is the 12V+ (always hot), terminated? Was it at the 12V battery post? Was it at another location, that is not obvious. Did they just tap into a wire that had a 12V+ and was of sufficient gauge wire to support the moonroof motor.
