Aftermarket Wheels and Spacers - confused
Discussion in 'Gen 3 Prius Accessories and Modifications' started by NavigatorRoth, Jul 26, 2015.
  1. NavigatorRoth
    NavigatorRoth Junior Member
    24
    31
    Pennsylvania
    Ok guys sorry for the post about wheel spacers, Yes I did search wheel spacers and all that did was confuse the heck out of me.. Just a couple simple question..
    Info on my car - 2011 Prius 3 all stock, it has 15" factory wheels on it now looking to go to 17" wheels
    1. Are wheel spacers neccessary?
    2. If so what size is a good size 15mm?
    3. If I put 17" wheels on can I switch back to 15" wheels in the winter (snow tires) without
    any hassle? Will the wheel spacers need to be removed if I switch back and forth between
    15" and 17" ?
    Thanks Guys I'm really not a car guy, but I am learning..
  2. Mendel Leisk
    42,164
    I know very little too, lol. When I hear "spacer" I think of spacer rings. These rings are needed with aftermarket rims, when the hub (center) opening is larger than the car's hub. With the stock wheels, either 15" or 17", spacer rings are not needed: the hubs are a close-tolerance fit. They're likely not needed with a lot of other Toyota rims too: I'm using Corolla 15" steel rims with snow tires, they fit just right, no spacer rings needed.
  3. NavigatorRoth
    24
    31
    Pennsylvania
    ok thanks, so if I can find factory 17" toyota wheels I should be ok without spacers?
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    no, spacers needed
    yes, 15 and 17 wheels can be used, and if the outside diameters are the same at the same time.
    if you buy an aftermarket wheel that requires a different offset, a spacer can be fitted, relax
  5. Mendel Leisk
    42,164
    If you enter your vehicle on TireRack, it'll show you rims that are compatible for offset, so no offset spacers needed. There's a certain range, slight variation but still ok. They will almost invariably need the hub spacer rings tho.
  6. NavigatorRoth
    24
    31
    Pennsylvania
    Thanks guys everyone has been helpful and I look forward to ditching the 15" and upgrading to 17" and then
    maybe I'll get the TRD spring installed to fill in the gap.
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Hubcentric rings, not hub spacer rings. ;)
    Used when wheels with larger center bores (than stock bores) are mounted on the car. Centers the wheels over the studs and relieves the studs from bearing the entire weight on the wheel.
    Spacers are used to address wheel offset, as mentioned in above post. Offset positions the wheel side to side relative to the hub. Hubcentric rings centers the wheel around the hub/axle.
    marvingloria2011 likes this.
  8. NavigatorRoth
    24
    31
    Pennsylvania
    xliderider do you have aftermarket wheels? If so what size and what did you use to make the wheels work? I ask
    because you have the same car as me.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Nope, stock wheels, sans wheel covers.
    I've mounted aftermarket wheels on previous vehicles though. Looks good, until some idiot runs a traffic light and crashes into you. :(
  10. NavigatorRoth
    24
    31
    Pennsylvania
    ouch, yeah thats no good.
  11. Mendel Leisk
    42,164
    Oh, and TireRack will automatically add the required hubcentric rings to the invoice, as long as you've entered your car. Any place would have the same database and software.
    Any aftermarket rim will have a hub opening too large: otherwise the manufacturer loses some of their potential customers.
    NavigatorRoth likes this.
  12. NavigatorRoth
    24
    31
    Pennsylvania
    Thanks again guys
  13. ncases
    ncases Senior Member
    609
    672
    Chicago
    I would refrain from using spacers I removed mine after costco noticed that I was using spacers and they will not do any job done unless its remove due to safety issue. If its not done correctly you will have wheels flying on a highway and your safety always be a concern. Look for an aftermarket wheels that has the width of 8-8.5 then you don't need spacers on these kind of wheels.
  14. xliderider
    8,140
    3,277
    Honolulu, HI
    Costco will not mount tires on non oem sized wheels where I live. They wouldn't even mount tires on a size rim that was a factory option on a higher trim level (aftermarket wheel, not oem wheel).
    ncases likes this.
  15. ncases
    609
    672
    Chicago
    I had mine stock but used a hub centric spacers back then to make the rear wheels flushed on the rear fenders. They advice me to take it out after realizing I had spacers on its rear wheels before doing any job.
