Aftermarket wheels on 2013 c
Discussion in 'Prius c Accessories and Modifications' started by Jamaikon, Apr 28, 2019.
  1. Jamaikon
    Jamaikon New Member
    Jamaica
    I have this idea, I have a 2013 Prius c and would like to upgrade from stock.
    What do you think about 205/50/15? those will be on 15*8 rims.
    I was wondering if I would have to worry about any touching in the wheel arch area..
  2. Royston.K
    Royston.K Member
    75
    60
    Singapore
    205 is too narrow for 8" width rim. you should be looking at 7" or 6.5" width for 205mm tyres. Also your ratio of 50 would be upsetting the overall diameter.
    205 50 16 for 16" for Prius C. However clearance & offset is also a factor which I've yet to measure haha.
  3. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    As seen from other Prius c owners in japan you can run a x9 rim but Turing ratio is out the window. I’m currenty running a 17x7 rim with a 205/45/17. Unless you want to run stretch tires then yes you can run a 205 tire on the rim. Is not will be a 215 you will run.
  4. Vdizzle
    Vdizzle Junior Member
    Rialto
    2015 Prius c
    205 will fit fine on 8 inch wheel. It will be lightly stretched if anything . I've ran 195 and 205 on 15x8 with no problems. If you go by manufacture tire recommendation, there gonna tell you its not recommended but like i said, never had issues with 205 on 15x8 in my experience. As for rubbing, you might have issues depending on how low you are.
  5. Vdizzle
    Rialto
    2015 Prius c
    Also for your speedometer, it will be off a few mph. I'm running 185/55/15 and my speedo is off by 3 mph. 205/50/15, my guess is your speedo is gonna read 5mph under. I use a GPS app and compared it to my car and that's how I know. There's also websites that can do the conversions for you. I believe running 65 series is optimal and 60 will be closes to stock without throwing off the speedometer.
  6. wildgatsby
    wildgatsby Junior Member
    29
    48
    Arizona
    You can get a set of older Miata rims! They usually sell on Craigslist/Facebook Marketplace for fairly cheap.
  7. Vdizzle
    Rialto
    2015 Prius c
    Miata wheels done! 15x6 13 lbs and 15 lbs tires. 28lbs combo compared to the stock 32 lbs setup.
  8. wildgatsby
    29
    48
    Arizona
    Vdizzle likes this.
  9. Jamaikon
    Jamaikon New Member
    Jamaica
    My offset will be 0
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    What exactly makes you think this will be an "upgrade" ?
    What are you trying to accomplish, really ??
    It might actually hurt your gas mileage.
