Air Bag lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sabercat, Nov 21, 2019.
  1. sabercat
    sabercat Junior Member
    48
    Mid-Mich
    2001 Prius
    I had a vendor attempt to have a remote start put on my 2010 Prius. He stated that he wired it in, but could not get it to work, this remote had it own FOB. After disconnecting the aftermarket remote system, I have the air bag light on/off, and blinking seatbelt disconnect lights lit up, by the glove box, I also have the airbag light in the dash lit up. Other things going on are, dome light does not come on when opening door, (will turn on, if I use the switch to turn on) but the light that is located at the bottom of door lights up. My FOB’s will not lock/unlock the doors, I must hold the FOB directly on the push start, to get it started. Trip A, and B resets every time I exit the car, and start it back up, both trips go to Zero, plus the clock is at 1, am or pm.
    I have disconnected the rear battery, but I have not messed with the wire connectors underneath the seats. I put new batteries in the FOB’s. Could the FOB’s need reprogrammed? Thanks in advance
  2. Elektroingenieur
    2,515
    3,258
    Three Touring
    It’s difficult to say, without knowing exactly what was done to your car, but I can’t think of any problem with the keys (remotes) that would also cause the other symptoms you describe. I suspect that part of the wiring has been damaged or disconnected, or perhaps that the remote starter (or some other extraneous device) is interfering with multiplex communication among the car’s computers.
    I’d suggest troubleshooting each problem, one at a time, using the information in the Repair Manual (more info) and Electrical Wiring Diagram.
  3. sabercat
    48
    Mid-Mich
    2001 Prius
    Thanks, they did remove all the remote wiring etc.
    I wonder if the 125 DC DC fuse located under the engine compartment, fuse box is the problem
  4. ChapmanF
    15,436
    It's either that or the gas cap. Simple elimination.
  5. ASRDogman
    ASRDogman Senior Member
    6,059
    3,253
    Take it back and make them fix it.
    Or remove it and put it back to original.
    Or take it to Toyota and have them fix it and make the place pay for it...
    frodoz737 and sabercat like this.
  6. bisco
    49,375
    what is a vendor?
  7. ChapmanF
    15,436
  8. sabercat
    48
    Mid-Mich
    2001 Prius
    vendor, I could have misspelled it, in this case, what I mean by it was a place that installs radios, electronic devices, remote starters etc.
  9. bisco
    49,375
    yeah, i have to think they messed something up. maybe left something unplugged
    sabercat likes this.
  10. sabercat
    48
    Mid-Mich
    2001 Prius
    for the 2010 prius, they do not have key reset button under the dash?
  11. Grit
    Grit Senior Member
    6,140
    4,053
    Wilkes Land
    Get your ECU checked.
  12. ChapmanF
    15,436
    Or start by letting the ECU tell you what it thinks needs to be checked.
    I'm with Elektro, ASR, and bisco in thinking there was some simple oversight in the vendor putting their toys away.
  13. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    How old is your 12v?
    Have you checked the health?
    Could they have drained it during installation?
    Does car start no issue?
  14. sabercat
    48
    Mid-Mich
    2001 Prius
    Not sure on the age, but the volts are good, over 14 when first started. Cant recall for sure, but before starting I think it was hi 12's
    when you hold the fob to the push button, starts great.
    #14 sabercat, Nov 23, 2019
  15. sabercat
    48
    Mid-Mich
    2001 Prius
    Last night I did drop the panel, the one with the TPMS button on, looked at the wiring, I did find 2 strands of coated wire, I assume that they was using to hook up the remote, it was taped to the existing wire harness going to the OBD port. Other than that looked pretty clean down there. Looks like there is a air bag in that area, so I didn't do much more then look. If I start moving wires around in that area, do I unhook the 12 volt battery, just to be safe on air bag not going off? what about disconnecting the big battery also, by removing the orange switch?
  16. sabercat
    48
    Mid-Mich
    2001 Prius
    Here is the wire
  17. sabercat
    48
    Mid-Mich
    2001 Prius
    I don't think this is factory wiring, didn't see any same color under there.
  18. bisco
    49,375
    if you have to hold the fob to the pushbutton, the fob battery is dead.
    and you are correct, there is no sks button under the dash on gen3.
  19. sabercat
    48
    Mid-Mich
    2001 Prius
    I changed the battery, and also tried the other remote.
    I'm wondering if they may have burned a fuse up somewhere. Thanks
  20. bisco
    49,375
    maybe the sks wire has been disconnected, or the fuse burnt
