Air Bag warning light stays on AND Cruise control flashes...help
Discussion in 'Gen 2 Prius Technical Discussion' started by Tynyyn, Jun 7, 2023.
  1. Tynyyn
    Tynyyn Member
    109
    29
    Bella Vista Arkansas
    As the title says, I have a problem. When this problem began I replaced the clock spring. Once it was installed the problem presisted so I took the steering wheel air bag out and saw that a connector was not pushed in properly and locked into place. I pushed the connecter home and buttoned the steering wheel back up and all was good for a couple of weeks. Then the air bag warning light lit up and the cruise control would flash when I engaged the button on the stalk. So I pulled the new clock spring out and replaced it with another new one. This time I made sure the connector was seated properly before I buttoned the steering wheel back up. Now, a couple of weeks has gone by and the same symptoms has begun again. The air bag warning light is on constantly and the cruise control light flashes.
    Since I'm on my third clock spring for this condition I'm wondering if there is another fix for this condition. Could the steering wheel air bag be bad? Could the cruise control stalk be bad? Tossing all this out there to see if anybody has some insight into this problem
    Thanks.
    51,690
    Are you using oem clock springs or fake Chinese junk?
  3. Tynyyn
    Tynyyn Member
    109
    29
    Well, fake Chinese junk, of course. It's hard to pass up a $18 clock spring on Ebay. But if you think that's the problem I'll certainly look into the more expensive option.
    51,690
    i can only tell you that it has been reported here that they fail early and often
  5. ChapmanF
    17,908
    Will asking the car for what it thinks the problem is ever start to look worthwhile?
  6. Tombukt2
    Tombukt2 Senior Member
    12,810
    2,303
    Durham NC
    I've installed both I haven't really had any problems yet with the cheap clock springs. With the cheap inverter pumps absolutely I just went away from the flat pancake pump permanently. But the clock springs I've had no problems with and I've got 60K on one. Generally I usually have enough spare parts cars around that I can just jerk the clock spring off of any of them it just takes literally 18 minutes so I haven't really had to play a lot with the cheap Chinese junk but I have one or two that are in use. And now I've gutted three or four more seven to nine generation twos so I have plenty
