Air-Con Compressor noise.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mr Gee, Nov 20, 2013.
  1. Mr Gee
    Mr Gee Member
    88
    30
    Australia
    Just put my car in for it's first year's service(20,000km). I made an observation to the service tech that during warm weather, there is a noticeable rattly whirring sound.
    During testing, they were able to compare my car with another and confirmed the noise to be from the air-con compressor. They have processed the warranty claim on this for me and hopefully, a new compressor will be fitted in a few weeks time. (y) for Ferntree Gulley Toyota
  2. Emcguy
    Emcguy Member
    176
    29
    Australia
    The Denso air-con is meant to be bullet proof! (Some of the local stuff is even made right next to Ferntree Gully!)
  3. ets_87
    ets_87 New Member
    I'm not sure if I have the same thing but if anyone can help that would be great. When the car is on but just using battery power and I turn the AC on it makes a whine type of noise that I consider to be somewhat loud. Not sure if this is normal but it definitely seems odd enough for me to post this. I can notice this sound easily when sitting in the garage and turn the AC on initially with the windows down. Not sure how long it has been doing this but does anyone know if this is normal?
  4. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    Normal. That sound is the AC compressor running. You don't hear it in a normal car because the engine is running. AC compressors are loud.
  5. Flying White Dutchman
    4,374
    313
    you can also check if there are no leaks
    a low or no level would also make the compressor run louder.
