air con..
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ikklesmiler, Oct 3, 2009.
  1. ikklesmiler
    ikklesmiler New Member
    49
    Kent UK
    Just a little question...
    Does the air con work from the engine? or will it still run when car is only running on battery? (ie under 30mph)
    Ann Marie :confused:
  2. PriusRoadWarrior
    76
    16
    Wisconsin
    What type of car do you have and what year???
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If you mean the Prius, Gen I (2001-03) used a belt from the engine, but Gens II (2004-09) and III (2010-?) have electric A/C. (in the US, but I suspect the UK as well)
  4. ikklesmiler
    49
    Kent UK
    Hi
    I dont actually own a Prius yet, have just put a holding deposit on one though so will be a proud ownder in about 2 weeks :cheer2:
    The Prius I am buying is a T Spirit 2003 53plate, its actually the 2004 model... (is a Gen II shape)
    I am also in the UK (not sure if the Prius's are the same..would hope so!)
    Ann Marie
  5. bwilson4web
    15,518
    New user, wrong group, probably need to move thread to NHW20 area. The reason is the NHW20 area has experts in your type of vehicle, it is the hatch back, right?
    You'll like that group.
  6. ikklesmiler
    49
    Kent UK
    what is NHW20 area??
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    In that case, yes, the A/C compressor is electrically driven.
    Tom
  8. ikklesmiler
    49
    Kent UK
    Tom, thank you for your help. :)
    Ann Marie
  9. bwilson4web
    15,518
    It is called the Generation II group and has sub-forums for specific areas. Because the different ways Europe handles the model year and the somewhat confusing way we do it in the USA, I try to use the vehicle model identifier:
    • NHW10 - sold only in Japan but occasionally shows up as isolated exports, this was the first Prius.
    • NHW11 - sold in Japan, North America and Europe, it is a sedan body (aka. saloon) shaped somewhat like the Ford Focus.
    • NHW20 - sold in Japan, North America, Europe and some Pacific countries, it is the hatchback with a much improved battery pack.
    • ZVW30 - today's model with a 1.8L engine
    I would recommend reading the Wiki article about the Prius. It will answer many high level questions. Then the NHW20 experts in the "Generation II" forum can fill in the blanks.
    GOOD LUCK!
  10. ikklesmiler
    49
    Kent UK
    Thanks Bob
    Yes it is the hatchback one.
    I was wondering if there was an area for people in europe. I will go look at that now.
    Thanks again.
    Ann Marie
  11. bwilson4web
    15,518
    There is a European, Yahoogroup, that is active. They've organized trips to meet up.
