Air Condition "problem"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Dec 16, 2021.
  1. lpf
    lpf Member
    113
    33
    Greece
    My A/C works fine. These week (with low temperatures around 45F) I see ICE coming on very often when I use the A/C. Is this normal? I usually set the temperature at 72F, if I set it higher ICE runs a lot.
  2. JC91006
    16,475
    8,393
    If you are warming the car (from 45 degrees to your desired temperature), the engine usually runs.
  3. lpf
    lpf Member
    113
    33
    Greece
    ICE comes on when I turn on the A/C, even downhill. That's my point.
    I don't remember this happening last year...
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    The car's heating system uses hot engine coolant passing through a heat exchanger to warm up the passenger compartment air. The engine needs to run to keep the coolant hot. The engine will cycle on and off to maintain coolant temperature as needed.
    When using just the AC, the compressor runs off electrical power from the HV battery, so the engine will only need to run long enough to charge the HV battery when needed. The engine cycle time varies greatly depending on how hard the AC compressor is running.
  5. lpf
    lpf Member
    113
    33
    Greece
    Thanks. I see this cycle as normal operation but with full traction battery it should not power up the ICE.
  6. JC91006
    16,475
    8,393
    How do you get heat without powering up the ICE? This is not a TESLA
  7. lpf
    lpf Member
    113
    33
    Greece
    Traction battery can care for that until falling below 40%. Then ICE starts to charge the battery. This happens when you are not moving but having the A/C on. When driving and the battery is full or mid-charged there is no need for the ICE to charge it.
    So, I assume that it is important "how hard the AC compressor is running" according to TMR-JWAP above
  8. JC91006
    16,475
    8,393
    When the temperature is 40 degrees, even with the AC button pressed and AC compressor running, the car is still trying to produce HEAT. You are trying to warm up the car to 70 degrees, you need HEAT. To generate heat, the coolant in the car has to get hot and circulate, thus needing the engine to go on
  9. TMR-JWAP
    6,193
    5,891
    Columbia, SC
    We need to remember that the AC compressor in a Prius is NOT a heat pump system, it is an "Air Conditioning only" compressor, used only for cooling air and reducing it's humidity level.
  10. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Later Prius Prime model has a heat pump.
  11. lpf
    lpf Member
    113
    33
    Greece
    Still you don't try to understand.
    A/C powers up the engine when driving without stepping the pedal, when coasting. I did not say when STARTING the car.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    3,430
    1,485
    NJ-USA
    Step back and describe what you observe when driving. When is the ICE running? What are the HVAC controls set to? Are you monitoring the HV battery SOC?
    How do you know that "the A/C is powering up the ICE?" We are trying to understand what info you put in your post, while trying to convey what we know about normal operating conditions that would cause the ICE to run.
    Having the air conditioning in use should only affect HV battery SOC, so the ICE usually doesn't come on during "glide" operation (below 40mph) unless SOC goes too low. Usually. Not always.
    If you have the HVAC set to blow air and the set temperature is higher than the outside ambient, then the ecu will force the ICE to run anytime the coolant temperature gets too low. Others here know the specifics, but having the climate control system set to blowing warm air means the ICE can run anytime. (The car has electric PTC heaters, but those are piddly little things compared to the main heater core).
  13. lpf
    lpf Member
    113
    33
    Greece
    Thanks. See my answers below.
    How do you know that "the A/C is powering up the ICE? I know because when I power off the A/C engine stops immediately.
    Outside temp around 45F, A/C set at 72F, driving normally. High speed blower triggers the ICE, lower speed does not.
    SOC more than 50%. Sometimes engine runs, this is the "problem"
    SOC in the reds: it is normal for the engine to run and charge the battery.
    If you have the HVAC set to blow air and the set temperature is higher than the outside ambient, then the ecu will force the ICE to run anytime the coolant temperature gets too low. Does the coolant temp gets low during driving and for what reason?
    From the above I assume that I have to check the a/c.This never happened last year. Except that you think that is normal.
    In the summer A/C works up to 15 minutes, just from the battery,
  14. ChapmanF
    15,448
    Maybe not everybody in this thread is using "A/C" to mean the same thing.
    The way I use it, the "A/C" is the system that cools the car, using compressed refrigerant. It would be active in the summer, at times when you have the set temperature below the outdoor temperature. It is electric and doesn't require the engine (except to recharge the battery).
    The way I use it, the "heat" is the system that heats the car, using the hot liquid circulated from the engine. It is active in the winter, or at times when you have the set temperature above the outdoor temperature. If the outdoor temperature is 45 ℉ and you have the setpoint at 72 ℉, you are using the heat.
    The heat function depends on the heat produced by the engine. It can continue for short periods with the engine stopped, just because the engine is a big chunk of aluminum so there's residual heat there and in the circulating liquid, but that cools it down fairly quickly, and then it has to start again.
    If you have an OBD monitoring tool that can show you the coolant temperature, you can quickly spot the thresholds where the engine starts and turns off depending on how the heat is set. It is fairly predictable, though there are a few unexpected details, some touched on in this thread.
    lpf likes this.
  15. lpf
    lpf Member
    113
    33
    Greece
    At last, somebody explained, thanks a lot!
