Air Conditioner Compressor failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aapopper, Aug 17, 2007.
  1. aapopper
    aapopper New Member
    29
    55k miles on 2005. Air conditioner compressor started whining. Local dealer checked with Toyota and then advised I would need a new compressor @ $1,300.
    Troy and extended warranty saved the day. 0 cost to me. Big thanks to PriusChat and Troy!
    BTW, wish me luck, local "factory trained tech" has never replaced a compressor before.
    Happened to anyone else?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You might want to change the tile on your post. This is not an "Air Compressor". It's a refrigerant compressor, but everyone will better understand the title if you call it an "Air Conditioner Compressor". I was expecting to find something about a tire pump.
    Tom
  3. aapopper
    aapopper New Member
    29
    <div class='quotetop'>QUOTE(qbee42 @ Aug 18 2007, 10:55 AM) [snapback]498316[/snapback]</div>
    Thanks for your suggestion. You are correct, it is quite ambiguous.
    I realized my error almost immediately after posting but was unable to change the subject line using "quick edit" and let it go at that. After reading your post, I tried again using "full edit" and was able to modify the subject line.
