Air Conditioner compressor noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Patrick Glass, Jul 29, 2014.
  1. Patrick Glass
    Patrick Glass Junior Member
    San Antonio, TX
    I have a 2013 Prius with few miles. It seems like the air conditioner compressor makes a very loud humming noise. It's a little annoying inside, but outside it is really loud. I know it is running off an electric motor and I expect that to make some noise, but this seems excessive. Is this normal? Also, the compressor keeps running all the time. I thought they were supposed to cycle on and off. It seems like all air conditioning compressors do this to conserve energy, even a house air conditioning unit.
    I'm afraid if I take it to my dealer, they will just tell me it's normal when it may not be. I really need to hear from other owners about this.
  2. Mendel Leisk
    38,644
    What are you setting the temperature at? And have you got the system on Auto? Is it cooling well? ( just some thoughts)
    I'd get in touch with the dealership first, take advantage of your warranty, see what they say.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I don't recall ever hearing mine run. Running all the time may be the variable speed function. Old technology types have to cycle on and off but the Prius can just lower the speed.
    hybridbear and Mendel Leisk like this.
  4. dandeman
    dandeman Junior Member
    61
    Chapel Hill, NC
    scroll compressors make quite a bit of noise on initial startup if the temperatures are hot... tend to quieten down after they have run a bit.. Home A/C systems using scroll type compressors can do the same....
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Yep it's a common concern and perfectly normal. The a/c compressor is driven by the HV battery so doesn't require the engine to run to power it, though as it draws about 4kw it quickly runs the battery low causing the engine to fire up. Normally the a/c noise of a traditional car is masked by the engine and fans. The noise settles down as the car cools down inside. If it continues to buzz then might be worth checking the gas level.
    hybridbear likes this.
  6. bisco
    49,371
    has the noise gotten louder, or has it always been loud? a few people have had new units installed under warranty because of noise increase. i guess it can be a sign of impending doom.
  7. Mendel Leisk
    38,644
    I don't think I've ever heard our AC compressor. My hearing's not the greatest, and we're not using AC much... Also, I'm wondering if what you're hearing is in fact the fans just in back of the radiators.
  8. Roland1555
    Roland1555 Senior Member
    282
    68
    Vancouver BC
    Quite normal for your car and climate. It is an advanced variable capacity system that has a lot more in common with a commercial 3 phase system than most average automobiles. Rather than cycle on and off, it is more efficient to keep the compressor running, it is variable, and will make more noise when it is running at full speed.
    All the normal things that you can do to help it applies.... park in shade if you can, open windows/doors to let the hot built up blast of heat escape, consider window tinting and sun shields for the front and possibly back window as it is sloped so much that it is almost a skylight.... you know, you live in Texas.
    Your system will run a little more conservatively, and efficiently if you use Eco mode.... but I know that when I was driving in 50 Celsius temps that I wanted it to blast.... but give it a try, and not to worry, nothing is wrong with that loud humming, it will tone itself down as it comes closer to satisfying whatever you have set the interior limit to.
    And don't be afraid to take it to the dealer and hear that it is normal.... you did them a favour when you purchased the car from them.
    Roland
    dorunron, kc410 and GrumpyCabbie like this.
  9. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    I agree with all of the above. Even our compressor is a little noisy, especially if it is running full speed. It is a variable speed unit, and makes more noise the harder it works. Depending on your settings of your climate control will affect the sound you are hearing.
    I suggest you run your climate control to a setting of somewhere around 76. Also use the "Auto" setting. If you are too warm or too cold, adjust the temperature a couple of degrees warmer or cooler. Running the system on "Lo" will cause the compressor to run all of the time and at full speed. You will also notice that on very hot days when using "Auto Mode" the fan will run very fast and the compressor will be noisy. Once the temperature in the cabin begins to cool down, the noise will quiet down and the fan will slow down also.
    If you feel that your compressor is excessively noisy, I suggest two things. First, visit your dealer and ask to test drive a similar Prius. If you find the sound is the same, then you should have a pretty good idea that everything is okay. But if you still feel your compressor is too noisy, at that point ask your service writer to have the system checked. Depending on when you purchased your Prius and the amount of miles on her, the work they do might be covered under warranty. Your service advisor can give you all the details on that aspect.
    Enjoy your Prius. It is the best midsize five door hatchback and the most economical out there IMO.
    Regards,
    Ron (dorunron)
  10. David Beale
    5,963
    1,981
    Edmonton Alberta
    50C! We are finally experiencing 30C days and everyone is melting. But we're NOT complaining. If you EVER hear me complain about it being too hot, please, just slap me upside the head! ;)
    In Edmonton Alberta we must not complain about it being too hot!
    So maybe my experience with the A/C system is not in your ballpark. :)
    dorunron likes this.
  11. dorunron
    3,318
    1,103
    Houston, TX
    I don't think your compressor will ever be noisy. Not with the temps you folks have up there!
    Regards,
    Ron (dorunron)
    PS If you think it is hot, try living in the desert like Las Vegas or Phoenix. Now that is hot! ;) Or you could just come visit me and we can compare Prius stories and enjoy the Texas heat. We have two seasons here. Summer and Winter... Not really, but usually spring and fall are short lived. This year seems to have been a exception... :)
  12. orenji
    orenji Senior Member
    5,884
    3,486
    I also had the same concern, and notice it is loudest when I first turned on the A/C, and I do keep my setting at low. However, recently I have noticed a vibration in the steering wheel when the A/C is first turned on too. And the car is nut moving......anyone experence this in the C?
  13. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    These two messages are right on target. This is one of the advantages of a hybrid or electric car with an electric AC compressor, it's more efficient that many ppl are used to & behaves differently from what is expected.
  14. Roland1555
    282
    68
    Vancouver BC
    It was 33 around here yesterday inland, and what made it more uncomfortable was the humidity. Not as bad as Toronto where I grew up, or down Florida way in summer... geez I can remember taking a jog around 7am in Lauderdale and just sweating buckets. I like a/c
    My experiences with high heats in this car was during a long summer road trip that included parts of California, Arizona and Nevada... with the obligatory exploration of Death Valley during a heat wave.
    If the car broke down in some of those places I think we all would have died, but it handled it like a champ.
    The fact that it is a 'dry heat' really does make a huge difference to your personal ability to tolerate it.
    Roland
  15. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Might the noise be from the AC condenser / radiator fan running ? That runs any time the AC is on.
    Also, the electric AC compressor in my 2010 Prius Does not turn totally off, it runs at different speeds to handle large or small cooling loads. The compressor is powered by a 3 phase electric motor. The Prius inverter must have a Variable frequency drive built in that runs the compressor only fast enough to meet the cooling needs for any temp or fan setting.
    I was playing with the AC system this summer on a hot day while parked and sitting in the front passenger seat with the window open so I could hear the compressor. I also wondered if the compressor just cycled on / off like a conventional system, or was it variable speed because it is electric powered ? With the car in ready mode, I switched on the AC. The compressor ran at full speed until the AC evaporator cooled to near the low limit. The compressor started to step speed down in about 50 rpm steps (stepped down about 5 times to about 1/2 speed). As I either increased blower speed or increased the temp setting, the compressor would step up the operating speed until the evaporator temp again neared the low temp limit.
    A very slick operating and efficient system IMO. :)
  16. dorunron
    3,318
    1,103
    Houston, TX
    To add to what John just wrote above, in many instances the compressor will cycle on and off once the cabin reaches the preset temperature. What seems to make it do that easily is if it not real hot outside. Example 85 Ambient 76 A/C Auto Setting. I have seen this happen more than once on our Prius. I also seem to recall the Gen II did something like too in certain situations.
    Ron
    Jon Hagen likes this.
  17. Jon Hagen
    336
    136
    North Dakota
    Thanks Ron, makes perfect sense. While my 2010 Prius AC compressor only went down to the low speed setting on that 85 degree July day, I can see where if the AC load was very low, it would need a way to totally stop the compressor to prevent over cooling the evaporator and clogging it with frost.
  18. Patrick Glass
    San Antonio, TX
    Thanks for all the comments! Yes, it is really hot in Texas this time of the year. The air-conditioner works fine. The compressor just seems loud to me. Sound is something that varies from person to person. Perhaps it's not any louder than anyone else's Prius. It just seems loud to me, especially when the engine is not running like at a stoplight. The car is garaged and not that hot in the morning and even then it is loud.
    I don't leave it on automatic, because the interior fan at full speed is so loud I can't hear my radio and the sound really annoys me. I turn the fan down and as soon as I do that, it goes off automatic. I just don't like automatic climate control and I'm thankful I can turn it off. I have a 2013 Honda Civic also and I'm really glad it doesn't have automatic climate control.
    Thanks to your comments, I learned that it is supposed to run all the time, unlike non hybrid cars so that concern can be eliminated.
    Yes, it does use a lot of battery power. My mileage in the summer is not nearly as good as in the winter. I've got to take it in for the recall and I'll talk to the dealer about this.
    Thanks again for all the comments!
  19. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Patrick,
    I have found my Prius has exceptional operation within an incredibly tight window of parameters. Move too far out of those, and you're cooked. My fuel economy drops in both winter and summer -- the a/c uses a lot of electricity and the heater requires a lot of engine running. Spring at fall, between 45-50 mph, dry, and overcast seems to be the proverbial "sweet spot".
  20. dorunron
    3,318
    1,103
    Houston, TX
    The above is exactly what I too observe.
    Ron (dorunron)
