Air Conditioner on while charging question?
Discussion in 'Prime Plug-in Charging' started by adamsocali, Mar 27, 2017.
  1. adamsocali
    adamsocali New Member
    When I turn my car off I always see this question "Can you use air conditioner while charging? or something like that. It also gives you a yes or no option. So, one time I selected "no" and the next time "yes". It then shows my driving score. Does yours do this? Is this just a random question the car asks or does my answer change some setting?
    Thanks in advance,
    adamsocali
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I just noticed my did the same and I selected yes. I think the question was for using the air conditioning to cool the battery while it is plugged in. I assume it is to help the battery life and I selected yes because of that.
    #1 in Easley,SC
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
  4. dalcon95
    512
    653
    For the battery's sake, you want to select yes.
    #1 in Easley,SC
  5. adamsocali
    Will this be asked then every time I turn off the car and the battery is low? I don't remember if I selected no or yes first! :)
  6. dalcon95
    512
    653
    After I selected yes, I haven't seen it again.
    #1 in Easley,SC
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    sadly for me that message has never come up:cry:hopefully maybe June/July?
    dalcon95 likes this.
  8. Insighter
    Insighter Active Member
    409
    287
    SoCal
    Hello all - I just bought a Prius Prime Advanced, and I love it already. I see the same message when I shut my prime off about allowing the car to use the A/C during charging. I want to always allow this, but, unlike you, it keeps popping up. Is there a way to set it to always use the A/C? I'm concerned that I will miss the message sometimes and it will charge without the A/C. Thanks
  9. dalcon95
    512
    653
    After making that post, I have seen the message come up again and again. Not sure if you can permanently keep the setting to keep turning on everytime it needs to. I use a scanning tool for adjustments and don't see it there either.
  10. El Dobro
    El Dobro A Member
    7,093
    3,271
    Definitely let the A/C do the job, you want to keep the battery in its happy place.
  11. Insighter
    409
    287
    SoCal
    Okay, thanks for letting me know that. Perhaps it's not possible to change the default? What did you mean when you said you use a scanning tool for adjustments? What is a scanning tool, and what does it do? Thanks!
    priuscatprimeguy likes this.
  12. priuscatprimeguy
    2,730
    2,640
    probably something like Carista:D
    https://www.amazon.com/s/?ie=UTF8&keywords=carista+obd2&tag=googhydr-20&index=aps&hvadid=241932768901&hvpos=1t1&hvnetw=g&hvrand=12926671049079529829&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9016788&hvtargid=aud-395617894931:kwd-66579838584&ref=pd_sl_76pdy3fjw6_b
    Insighter and dalcon95 like this.
  13. dalcon95
    512
    653
    A scanning tool is used to used to look up faulty codes if an engine light comes on. Certain scanning tools like I have can change settings on the car like changing the reverse beep and such.
    Insighter likes this.
  14. Insighter
    409
    287
    SoCal
    Hi Dalcon95 - Which scanning tool do you use, and does it require a paid subscription? Thanks
  15. dalcon95
    512
    653
    Insighter and priuscatprimeguy like this.
  16. Insighter
    409
    287
    SoCal
    Does that Carista allow you to program in another electronic key? Or is there some other way to do it other than paying the dealership to do it? Thanks!
  17. dalcon95
    512
    653
    That would be something you would have to take to the dealer for.
  18. Ovation
    Ovation Active Member
    156
    130
    Quebec
    Does anyone know if this situation (saying “yes”) means a Level 2 public EVSE will be notably less efficient at charging the traction battery? I initiated a session yesterday in quite warm conditions after having driven the car over an hour. The charger put in nearly 1kWh of electricity according to my app for that network, the A/C was on, and after 37 minutes (had to leave earlier than expected) I went from 0 to 2% (I was expecting at least 8-9%). I’m trying to determine if this is normal or if the EVSE was not working properly. To be fair, the car interior was nice and cool.
  19. Lee Jay
    5,850
    4,036
    If the battery is hot, it won't charge the battery until it gets it to a cooler temperature, and it uses the EVSE power to run the A/C to cool the car and the battery. It probably didn't start charging for most or all of the time you were there.
    Normal 208V charging is almost 1% per minute. Normal 240V charging is 1% per minute.
    jerrymildred likes this.
  20. BiomedO1
    BiomedO1 Senior Member
    4,116
    2,160
    SacTown, Ca
    I just experienced this last week. It was 100 degrees and I optioned to use AC to cool the traction battery. I was parked and charging on an L2, for 45 minutes and only got 4% increase SoC. This would normally get me to at least 30% SoC. The car interior was as cool as the building that I just left.
