air conditioner stop responding
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ben 1989, May 19, 2015.
  1. ben 1989
    ben 1989 New Member
    israel
    Hello.. Today was avery warm day... I pressed on the air conditioner button.. On the screen it looks like everything is ok.. But actually nothing happens.. The air conditioner is not turning on at all.. Somebody know what can i do? Thanks!
    49,734
    did you turn the fan on?
  3. ben 1989
    ben 1989 New Member
    israel
    Hi.. Yes.. The fan.. And even if i press a/c.. Nothing happens..
    49,734
    so the fan won't come on? if so, is there a fuse?
  5. ben 1989
    ben 1989 New Member
    israel
    It won't come on..
    I am sorry i don't understend in this.. I need to check the fan fuse?
  6. bisco
    49,734
    whatever fuses are involved with the hvac system.
  7. ChapmanF
    15,924
    My car is a generation 1, so I can't translate this advice directly to your car, but on mine there are trouble codes you can read from the heat/AC to find out what the trouble is. On the Gen 1 there is no special tool needed to read the heat/AC codes, just the right sequence of doing things with the controls.
    I would be really, really surprised if your generation does not also have trouble codes you can read from the heat/AC ... if nobody else knows how, it would only take looking in your service manual on techinfo.toyota.com to find out how.
    -Chap
  8. ChapmanF
    15,924
    If this post is right, it's pretty simple to do by turning the power on while holding the brake and the right two steering wheel buttons.
    -Chap
