Air Conditioning and MPG
Discussion in 'Gen 2 Prius Main Forum' started by momstoys, Dec 19, 2004.
  1. momstoys
    momstoys New Member
    35
    Reading posts with mpg charts, I see gas mileage goes up in the warmer months? Since you are likely to be using the air conditioning, why doesn't it go down like it does in my Corolla?
  2. Tideland Prius
    16,195
    For one thing, the air conditioning in the 04/05 Prius is running on an electric inverter so it doesn't need the engine running to provide cold air. Also, engine idle times are greatly reduced since the ambient temperature is much warmer and thus the engine doesn't have to run for long to get up to operating temperature.
    Perhaps someone else can provide an even more detailed answer?
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    battery efficiency, better in warm temps, less rolling resistance in warm weather, less use of the heater which takes the ICE coolant temp down quicker resulting in more ICE operation, and the psychological effect of cold weather, which results in the " I gotta get there quicker to get out of this cold air", nothing like cruising along with the window down enjoying a warm breeze.
  4. DaveG
    DaveG Member
    806
    Vancouver, BC
    They had a great segment on Mythbusters recently, comparing milage using an SUV with air con running, vs one with the windows rolled down.
    In the end, the windows-down SUV managed 15 laps (7.5 miles) more than the AC SUV.
    Of course, our Priuses use a different AC system as has been mentioned here, but it would be interesting to do the same test to find out what the difference is on a Prius.
    Not that I really care mind you, if it means comfy driving instead of being hot and cranky, I'll happily lose a few MPG. My 04 handled the 39c (102f) temps in northern California in the summer without any problems whatsoever. Of course, it felt like stepping into a blast furnace from the 23c (73f) temps inside the car.
    Dave.
  5. daniel
    14,487
    1,518
    Spokane, WA
    I think if you compare, say, 100 degrees to 70 degrees, you'll get better mpg at 70, when neither heat nor A/C is on.
    However, if you compare 20 degrees to 100 degrees, you'll do better at 100, because running the heater forces the engine to run a lot more. And at 20 below zero, the battery becomes inefficient and the engine almost never shuts off.
    In the Corolla, the engine has to run all the time anyway, so the cabin heat is free. In the Prius, in warm weather, the engine shuts off a lot, providing tremendous gains in efficiency. But in cold weather, a good part of that efficiency is lost, therefore mpg drops significantly.
    The Prius still gets better mpg than the Corolla at cold temperatures, but the difference is a lot less than it is in warm weather.
    So to summarize: both hot and cold weather take a bite out of Prius mpg, but cold weather takes a bigger bite. Cold weather does not take as much of a bite out of the Corolla's mpg, because it's always burning too much gas anyway.
  6. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Also, 04/05 prius has a variable speed compressor and continuously variable cabin fan. Once the cabin has cooled down, the most efficient speed of fan and compressor is used to maintain that temp.
    In a corolla, you regulate the cabin temp by either fan speed, or adding heat from the heater core, the latter being grossly inefficient.
  7. joereyes
    joereyes New Member
    In 82 degree outdoor temperature, I was on highway at 55 mph. I reset the average mpg, turned on a/c and I averaged 48.7 mpg for 10 miles. I turned off the a/c, reset the average mpg, and averaged 45.5 mpg. With the a/c off, I observed the electric motor kicking on,momentarily, about every 1-2 minutes. With the a/c on, the electric (engine that propels car) only kicked on (to help the gas engine) twice during the 10 miles. I believe the electric will kick on at high speeds so the battery doesn't over charge. One would think that the voltage regulator would do this. The engine charges my battery much faster with the a/c off. The only thing I can thing of that engaging the electric engine momentarily puts drag on the car, reducing mpg. I need more information, but as of now, I plan on running a/c on 90 degrees in the winter. Any information on this and /or the voltage regulator would be great appreciated.
  8. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I think you should post in the Gen III forum, this is for Gen II and will be different in some details.
  9. joereyes
    joereyes New Member
    I forgot to include that I could feel the car slow, while the electric motor kicked on. In my humble opinion, the above comments are correct, but it doesn't explain why my mileage increased with a/c on in same ambient temperature. Please help.
  10. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Don't want to sound rude, but you are driving a Gen III and you should ask these sort of things in the Gen III section of the forum.
    I can't help you since I am not familiar with the Gen III. I do know they are different than the Gen II I drive.
    You should get more and better response if you post in the Gen III section.
    Best of luck to you and welcome to Prius Chat.
  11. sportcoupe
    sportcoupe Junior Member
    44
    9 year old post!
    TheEnglishman likes this.
  12. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    Likely brought up by the new member.
