Air Conditioning failure!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by benlenz, Jul 30, 2007.
  1. benlenz
    benlenz Junior Member
    31
    Sunday, my air conditioner (the cooling part) just stopped working. I got in and started driving, hit the A/C Auto button and got only hot air. Everything was 100% fine the day before.
    So, the fan works. Which means it's most likely the compressor. I have noticed that when I turn it on, I don't hear the usual "jet engine startup" noise (like a rising pitch whine) I usually hear. What I do hear is like a rapid "tap-tap-tap-tap-tap" and then nothing, and then the tapping again.
    To me it sounds like the compressor drive motor ain't drivin'. Or the compressor is seized.
    Thankfully it's still under warranty. :D
    I guess I'm wondering if maybe with all the prius's complexity, there's like a reset button I need to press and the whole thing is fine again. Anyone know that button?
    Thanks
  2. Tideland Prius
    16,128
    the POWER button? lol.
    Hmm, I don't know. Hopefully it's nothing too major.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Sounds like several other reported instances of a rock knocking a hole in the AC condenser. That's a road hazard and not a warranty event.
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(garbageman @ Jul 30 2007, 07:14 PM) [snapback]487769[/snapback]</div>
    The most commonly reported cause of air-conditioning failure is road debris damage to the condenser which results in loss of refrigerant. That, unfortunately, is not covered by the warranty but may be by your car insurance.
  5. Malarkey
    Malarkey New Member
    146
    Connecticut, USA
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jul 30 2007, 10:33 PM) [snapback]487788[/snapback]</div>
    Has anyone successfully protected the condenser? I worry about stuff like this...
  6. benlenz
    31
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jul 30 2007, 07:33 PM) [snapback]487788[/snapback]</div>
    Uh oh.
    I have the extended warranty. Does that help?
  7. lchamp
    lchamp Veteran Member
    60
    I have the exact opposite problem. Yesterday, my a/c fan stopped working. I have checked the fuses...that one under the dash is a real trick.
    I know the cooling system works, because when I let air flow through, cool air flows (slowly) from the vent.
    I couldn't get an appointment today, so tomorrow will be the day to learn if it is a serious problem.
  8. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(garbageman @ Jul 31 2007, 12:49 AM) [snapback]487901[/snapback]</div>
    No. Do you have comprehensive coverage as part of you car insurance policy? That would cover it.
  9. exito3
    exito3 New Member
    <div class='quotetop'>QUOTE(garbageman @ Jul 30 2007, 09:14 PM) [snapback]487769[/snapback]</div>
    BTW. Did you had it fixed? What was the problem? I have the same problem
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Malarkey @ Jul 30 2007, 10:34 PM) [snapback]487807[/snapback]</div>
    Yes, I made a screen out of that black plastic gutter guard you apply to your eavestrough to keep the leaves out. Since I'm always finding small rocks embedded in the gutter guard, it must be working fine. This has been covered before, but the following photos will assist you
    Prius_Angie likes this.
