Air Conditioning Lowers Hybrid Fuel Economy
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Dec 22, 2005.
  1. Tideland Prius
    16,123
    The latest results from an ongoing evaluation of hybrid cars indicate the use of air conditioning has a dramatic effect on hybrid's fuel economy. "The hybrids we tested got 15 to 27 percent lower fuel economy with the air conditioning on," said Jim Francfort, principal investigator at the Idaho National Laboratory in Idaho Falls, which is operated for the Department of Energy.
    Francfort has been evaluating hybrids for nearly five years. In 2001, while testing the Honda Insight and the first generation Toyota Prius—the first two hybrids introduced in the United States—Francfort and his team saw, "big influences from air conditioning." He said, "It was new technology and we were trying to learn. We thought we needed to do more tests to understand the impacts on fuel economy, based on how hybrid owners actually drive their cars."
    Full Article
  2. 200Volts
    200Volts Member
    429
    43
    Northern CA
    WOW, that's more then I expected. Maybe those guys looking at solar cells should wire them to the A/C unit.
  3. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    During the summer, I ran the A/C Auto much of the time and found that if I kept it set at 72 that it had no effect at all on mileage. Sounds like another goofy-assed test where the "testers" have no idea what the hell they're doing.
  4. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Hmmm... HybridVigor's down in Phoenix and he's reported a drop of a few MPG in 110 deg heat with the AC on full. <_< Furthermore, my MFD vs Manual Calc numbers have never been anywhere near that far off except with it's really cold out and the bladder has shrunk. Where do they get that number? <_< I believe the MFD more than the manual calc because of the bladder and differences in the autocutoff theshhold of different gas pumps. There are just too many variables there to be really confident of those numbers. They're a good sanity check though.
  5. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    I'm in Dallas and I do see a small decrease in mpg with A/C on. See my graph of mpg vs average tank temperature at the bottom of Paul's Prius Web Page. I'm only seeing about a 3-4% penalty.
    Cold weather has a much larger negative impact.
  6. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
  7. brandon
    brandon Member
    771
    Manhattan, KS
    Tripp has a good point. How did they measure fuel economy, and was the method of measurement consistant in each test vehicle?
  8. ChrisA
    ChrisA New Member
    Round Rock, Texas
    The Prius system employs an electric motor to exclusively power the AC compressor. I would have thought that this would enable an air-conditioned environment without using engine power, and as a result would not decrease MPG.
    On an opposite side of this discussion, what impact does the the electric motor have on providing quick heated air to the cabin? If the Prius does not have an adequate supply of heated water from the engine cooling system (i.e, Prius running off motor and not from engine) it seems like it would take longer than an acceptable amount of time to provide ready heat to the cabin. I do not own a Prius yet (Feb delivery) so maybe someone could comment on this.
    Chris A.
  9. tripp
    4,717
    79
    Denver, CO
    I think the hit comes because the ICE has to charge the HV Battery more often because of the drain the the climate control places on the battery.
    Also, the chart in the article is interesting because the GEN I and GEN II Prii got nearly identical mileage in their study. The HAH got worse mileage than the Escape. I know that the HAH is more of a performance hybrid, but still.
    BTW, how low can you set the climate control? I haven't really used it much. Perhaps these guys have it set on -40F so that they can simulate winter driving at the same time. :p
  10. Kiloran
    Kiloran New Member
    1,225
    Since all the Prius's energy ultimately comes from burning gasoline, heating and cooling must necessarily reduce MPG.
    By how much is the real question.
  11. Godiva
    Godiva AmeriKan Citizen
    10,339
    Doesn't running the air conditioning lower the fuel economy of ANY car?
    And I might add I NEVER crank the air conditioning up to the highest level. I don't run it at the chilliest temp and I don't run it at the highest fan and I certainly don't do both at the same time.
    Then again....I don't live in Phoenix.
    I found this significant:
    " The testing also dispelled a persistent myth that the rechargeable batteries need to be frequently replaced. Francfort originally thought their battery evaluations would "go to 100,00 miles because that's how long the batteries are under warranty. The batteries were working so well, we thought we'd go further." They finally settled on 160,000 miles. Evaluations showed that the rechargeable batteries lasted to 160,000 miles with no effect on fuel economy."
    I also found this interesting but would like to know how they proved it:
    "Francfort and his team also determined that the computer dashboard readings for fuel economy—which most drivers use to base their judgment rather than manually calculating the actual mpg—inflates mileage numbers by somewhere between 10 to 20 percent."
  12. tripp
    4,717
    79
    Denver, CO
    yeah. I wonder what kinda impact it has? You'd think more because the alternator supplies the juice (this is correct, right?) and it's a belt driven system. Belt driven systems have a lot of mechanical loss involved in their operation.
    Yeah, I found it lame that they didn't state how they measured their fuel consumption so that their work could be replicated or at least inspected. Seems like a specious argument to me.
  13. tag
    tag Senior Member
    2,526
    Chicago
    Same, same, and SAME! My MPG goes waaaay down in the winter months and it seems to happen regardless of the length of my trips. In the summer, I may take a small hit but it's more likely due to short trips rather than running the A/C often. I've noticed virtually zero impact on longer trips despite the fact that the A/C is blasting away.
  14. Frank Hudon
    Frank Hudon Senior Member
    4,147
    just like every other vehicle on the road.
  15. tripp
    4,717
    79
    Denver, CO
    Hmm. We had a week of highs in the teens and single digits a couple of weeks ago and I didn't notice a huge hit. I lost about 5 MPG (~51 to ~46). I did get my block heater installed just in time. I have a short (5 mile) commute that takes about 10 minutes and I do a couple of other routine trips (lunch time hockey) a couple of times a week that are more like 20 mi round trip. On a cold night (0 F) when I had just filled up my tank I had to drive about 20 mi on the freeway and I still got right about 46 MPG starting with a fairly cold engine and no block heater.
    Tag, how much of a hit are you taking? Just curious.
  16. tag
    tag Senior Member
    2,526
    Chicago
    Well, tripp, how about in the neighborhood of 10 MPG? My problem, however, is I just can't deal with the cold anymore. I'm generally okay until it drops below 30 degrees and then, well, I'm not okay. Below 20 degrees, forget it! I find that I have to run the heat just about ALL the time (and that's in any car, not just my Prius).
  17. scrivener
    scrivener New Member
    los angeles
    I ran my air conditioner continually during the (Los Angeles) spring, summer, and autumn and found the only time mileage was affected was in very heavy traffic, when the AC drained the battery and the ICE had to recharge it. Now that I'm not running AC I find the gain in fuel economy is only about 1-2 mpg.
  18. BT Tech
    BT Tech New Member
    885
    South Florida
    Living in South Florida the weather here is usually hot and humid. Over the last several weeks the temps have been in the 60's so there has been no need for A/C.
    I have noticed a 3-4 MPG improvement in my 2005 in gas mileage due to not running the A/C.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  19. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Which uses more energy at highway speeds in the Prius, or any car with a low CD, windows open and AC off or windows up AC on? Did they take things like this into account during their test?
  20. tripp
    4,717
    79
    Denver, CO
    I hear ya. I'm still in that no surrender stage. When it's cold here I bundle up and wear gloves. I only run the heater when I'm coming back from a hockey game and the car's all steamed up. Then I run the defrost its only in pulses to clear the window. Then I shut it off and the AC too. We'll see if I'm this stubborn in a year.
