Air Conditioning setting
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by randomwalk101, May 6, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    269
    texas
    Anyone knows how to turn OFF the passenger A/C disable feature? I apologize but I forgot the exact term that Toyota calls it but there is a button that is when pressed (on), it turns off the passenger size A/C vents. Also, there is a setting in the main console that allow for all vents (which is the same as the button).
    Anyways, I turn it OFF (allows for all vents to be active) both using the button method or via the console mode. Anyways, as soon as I turn the car off and back on, the damn button is automatically enabled (disable the passenger side a/c vent) again...
    'LectroFuel and ETP like this.
  2. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Could it be using the sensor that detects weight in the passenger seat?
    ETP likes this.
  3. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    There is a button that turn the under seat rear AC vents off. But the other vents, I thought, were manual.:) BTW, does it take a few drives for the AC to work cold. Off the delivery truck it was a little wimpy.
  4. dstahre
    dstahre Member
    74
    35
    Cahokia
    Four Touring
    It looks to see if the rear doors were opened. If they were then it figures you have passengers otherwise it shuts it off! The button that shows people on it (top right) will turn if off if the doors had been opened but I know of no override!
  5. ETP
    2,801
    1,170
    Auburdale FL
    My disable rear vents seems to stay on but will try the door trick today. Doors do not do it. Might try a passenger in the rear seat next.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I think when you turn the vents off, you then have to put the climate in AUTO mode, then it will remember the last settings when you turn the car off.
    ETP likes this.
  7. ETP
    2,801
    1,170
    Auburdale FL
    Mine seems to work fine in manual. Maybe
