Air Conditioning vs. Best EV Mileage?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by planeflyer, Apr 3, 2012.
  1. planeflyer
    planeflyer Junior Member
    26
    Canby Oregon
    What settings on the airconditioning/climate controls results in the best mileage. Yesterday, while in EV mode with 8+ miles remaining, I pushed the AC button. The EV miles remaining quickly dropped 7, 6, 5, 4 in less than a minute until I quickly saw what was happening and turned the AC off.
  2. SBFJohn
    SBFJohn New Member
    Peoria, AZ
    Here in Arizona I have engaged AC while in EV mode. Typically I see a 10-12% drop in the EV range at that point. However I have a 3.1 mile commute and the last 2 trips with AC on at 72 degrees I used up 2.5 miles EV and drove 100% EV to work. :)
  3. Ichiro
    Ichiro Member
    335
    SF
    Did you also have ECO mode engaged (OP)?
  4. planeflyer
    26
    Canby Oregon
    Yes, I was operating in ECO-EV mode.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    You are just seeing the result of averaging.
    More useful is to know consumption rates.
    Moderate AC once the cabin is cooled off is about 500 - 1000 watts
    Moderate driving is about 7500 watts
    So expect AC to drop range 5 - 10%
  6. bisco
    49,694
    for best mpg's gas or electric, set fan to 'off', heat to 'low' if anything is on, it will cause more battery usage and/or gasoline.
