Air Conditioning Works Intermittently
Discussion in 'Gen 2 Prius Main Forum' started by sdtravelin, May 20, 2010.
  1. sdtravelin
    sdtravelin New Member
    San Diego
    2006 Prius with 58,000 miles. Drive in San Diego and Palm Springs. Earlier this year, the A/C would just cut off, maybe about once a week. The control panel indicated the A/C should be on, but absolutely no function. Drive around for 20 minutes, and all of a sudden, it would come on and work perfectly. It is starting to happen on a daily basis now...sometimes it won't work from start, other times it just cuts out while driving. I can park the car and shut the car off with the A/C working, then come back 30 minutes, and no A/C. It doesn't seem to matter which setting is selected. The control panel accepts all commands, but no function changes when the A/C has shut itself off. Loose connection somewhere? It works about 90% of the time, and blows very cold. When it shuts itself off, no air passes through the vents at all. Thanks
  2. sdtravelin
    San Diego
    Clarification...I don't recall it actually shutting off while driving, it just won't work sometimes on initial startup....about 1 in 5 times now. Then after 5 to 25 minutes, the A/C comes on. Thanks
  3. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    If it's in the normal auto mode it will only blow cold air if the interior temp is above the set point, or hot air if well below if the engine is warm. It isn't like the old systems. This may be your problem. Check for auto and what the temp setting is (push temp button on the steering wheel and look at the display)
  4. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    this used to happen to my car i pinned it down to a solar sensor once i erased the codes on the a/c ecu the problem went away
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    The auto system should always blow SOME air though...unless it is off. It will always be circulating air.
    Sounds to be like a bad blower motor...
  6. chico-prius
    chico-prius New Member
    los angeles california
  7. chico-prius
    how did you find/erase the codes??? (BTW, I'm having the exact same problem on 09 Prius. A/C and fan work when car is cold. If left out in sun, A/C and fan won't come on for 5-25 minutes, even though display says they're on. Dealer wanted $1,725.00 to drop dash and check evaporator with "no promises" it would fix problem ... LOL, yeah, right !!!)
  8. Mazinio
    Mazinio Junior Member
    Los Angeles
    Hey chico, did you ever find how to erase those codes? I'm having exactly the same problem with my prius now for the last couple of years. In extreme heat sometimes the a/c won't turn on, now it's winter and the heating decides to work only 40% of the time. Did you figure out what the problem actually was. Could really use some help.
    Thanks
  9. ArthurR
    ArthurR New Member
    Hallandale, FL
    Hi guys, I'm having same issue. The previous owner changed the compressor, so it started to.work. I bought the car and as soon as I left the whole thing shut down on the highway at night in rain 6 lanes me in the middle (no lights no power steering brakes nothing). I get few error codes, one P0A93 which is the inverter water pump. I changed the battery, became worse and would shut off. Got a brand new 12v battery yet again, now betit's better. But sometimes the compressor goes on sometimes just turns off and blows unconditionned air. Sometimes I let the car sit off for 20 minutes and ac would turn on. Sometimes not. I now have 2 12v batteries connected lol and car is functioning better but still. Setting dont matter, auto or not doesn't matter (never use auto, I'm iMiami the setting is always on 69. The red triangle of death is on. Just very weird things are happening with the car. I do deliveries at 3 jobs and it's now getting to a point where I'm tired of spending money and not getting the ac problem fixed. Also oxygen sensor code but that really shouldn't have anything to do with this. Any help will be VERY VERY APPRECIATED!
  10. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Have you checked to see if the inverter pump is working? Take the cap off the inverter reservoir, you should see the coolant flowing. If you don’t there is a problem.
  11. Mazinio
    Los Angeles
    Hey did to ever find how to resolve this. Having the same problem. AC not working at all then might kick in after a while, sometimes not at all. It's getting hot here in LA and am dreading it. Seems like something electrical for sure. Ok I'm aboto change 12v battery. Fingers crossed.
  12. Mazinio
    Los Angeles
