Air Conditioning...
Discussion in 'Gen 2 Prius Fuel Economy' started by h2photo, Jun 22, 2007.
  1. h2photo
    h2photo Member
    432
    Chandler, AZ
    Ok, living in AZ A/C is a MUST! After the car sits outside all day its literally 190(or so it feels like) inside. I mean, I keep hot-pads in the car for the steering wheel! But onto the real reason for this post.
    My husband and I were discussing the fact that I leave mine on Auto A/C & rarely just put the fan on. I do change it from LO (right when I get in the hotbox) to 80 (once its cooled down). But I leave the Auto A/C on at 80.
    Do the differences in A/C temperature cause different MPG outputs?
    I hope this makes sense!
    TIA!!!!
  2. Tyrin
    Tyrin New Member
    272
    <div class='quotetop'>QUOTE(h2photo @ Jun 22 2007, 09:02 PM) [snapback]466698[/snapback]</div>
    The Auto A/C is smart. If you just leave it on 80, it will cool to that temp just as fast as if you turn it to LO first or turn off the Auto. Of course, up here we have the problem like today, when it was actually cooler than my A/C temp, and so I found it pumping hot air! That's when you shut off the auto, and just use the fans, no A/C. For you this probably doesn't happen until late fall...
  3. h2photo
    h2photo Member
    432
    Chandler, AZ
    <div class='quotetop'>QUOTE(Tyrin @ Jun 22 2007, 07:08 PM) [snapback]466701[/snapback]</div>
    Yea I heard it was cool & rainy in Iowa today! (I'm originally from Ames)
    Thanks for the info
  4. Tideland Prius
    16,123
    Depends. Sometimes if you pump the temperature up high enough, it'll turn off the A/C. (In my area, that's usually 24°C. 23 and below and the A/C comes on)
  5. PriusBoyAZ
    PriusBoyAZ New Member
    62
    I live in Buckeye and drive to Scottsdale regularly. I have my A/C set to 75 or 80 degrees and get 50-55 mpg freeway. From my experience, using the A/C makes little difference in real-world gas mileage. Other factors, such as wind, road conditions, speed, and driving style have a much greater impact.
  6. pyccku
    pyccku Happy Prius Driver
    235
    Surprise, AZ
    Ha ha ha....fall...yeah, those temperatures won't be low enough to use the van until late November or early December if the weather was like it was this past "fall"!
    Right now it's 112.5 on my front porch. Thank God for A/C!
  7. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Running the auto climate control at 80F hasn't hurt my fuel economy all that much. It makes more of a difference in stop & go since battery capacity diminishes visibly. I might get 55mpg when I would otherwise get 60-65mpg. But my commute is mainly on the open road at 50-60mph and I've been getting 57-58mpg instead of 60-61mpg. I say leave it at 80 and don't worry about it.
  8. desertbriez
    desertbriez New Member
    376
    79 seems to be my magic number.... we've been over 100 for the past several days (and 114 when we head to the low desert!)
    i do think the a/c has had a negative impact on my FE.... but then i haven't had the car long enough to really know that as a fact////
  9. alexstarfire
    alexstarfire New Member
    220
    It kills my MPG n stop and go traffic. Seriously, from about 65 MPG to 30 MPG at best. I don't use the highway though. One, because I don't like our highways, and two, because the places I go I don't need the highway.
    I agree that on the highway that the AC really doesn't matter. However, in stop and go it's just killer when the engine is almost always running.
  10. Blegate
    Blegate Prius Gen III 2013
    132
    Vancouver, WA
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
  12. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    By stop and go, do you mean on a freeway where you stop momentarily, or stop lights, where you sit for 2 or 3 minutes?
    I avoided using my air conditioning due to FE concerns, but I thought I would give it a try the last couple days after I learned ir ran from the batteries rather than the ICE. There was hardly any noticible difference in cruzing or stop and go freeway. Maybe about the same as added drag from having the windows down.
  13. alexstarfire
    220
    My stop-n-go = traffic lights. And believe me, the lights are there to make traffic, I swear.
  14. Malarkey
    Malarkey New Member
    146
    Connecticut, USA
  15. NoMoShocks
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(Malarkey @ Jul 5 2007, 07:43 AM) [snapback]473444[/snapback]</div>
    The only time I would worry about turning the AC on and off causing excessive wear and tear is if you turn it on and off so rapidly that it doesn't have a chance to reach an equilibrium of pressures (high and low side) before you switch it back the other way. I would guess that 30 seconds would be more than enough time for the system to reach an equilibrium in operating pressures.
    If you cycle it on-off-on imediately, I think you can cause a fluid hammering effect in the compressor, that is not good for it.
    The AC is turning itself on and off all the time as a normal operating mode.
  16. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :mellow: Back to basics: There is only one source of energy in the Prius = gasoline. The energy used to power the Air Conditioning system must ultimately be replaced by gasoline. Since there are a multitude of factors influencing the MPG of a Prius (or indeed any car), it would be virtually impossible to determine how much the Air Conditioning system affects your fuel economy with the possible exception of laboratory conditions. I can attest that the Dallas TX hot summer does reduce my MPG, but how much I really don't know.
    I just set my Climate controls to "AUTO", select my desired temperature and let the Prius do the rest.
  17. rubencisneros
    rubencisneros New Member
    Grapevine, TX
    <div class='quotetop'>QUOTE(Charles Suitt @ Jul 5 2007, 11:41 AM) [snapback]473510[/snapback]</div>
    Ditto for me
    Hey Charles,
    Do you show your cat?
  18. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    <div class='quotetop'>QUOTE(PriusBoyAZ @ Jun 24 2007, 11:08 AM) [snapback]467297[/snapback]</div>
    I totally agree. Why suffer heat stroke for a few mpgs? Get comfortable, and enjoy the ride.
  19. richard schumacher
    7,663
    1,038
    United States
    Keep in mind that the battery system gets its cooling air from the cabin, through the vent to the right of the rear seat. Turning off the A/C in hot weather can reduce fuel economy because the battery system can get too hot. Rule of thumb: if you are too hot, then so is the battery, and you should turn on the A/C.
  20. adtech
    adtech Junior Member
    I must be missing something here about using the a/c. If the compressor is electric and the battery is running it, how does that affect mileage if say the battery never runs out and requires the ice? Does recharging going down the road put an extra load on the ice?
