Air outlet of modified air conditioner in rear row
Discussion in 'Prime Accessories and Modifications' started by sdhzlgl, Oct 20, 2019.
  1. sdhzlgl
    sdhzlgl Junior Member
    32
    montereypark
    When the front row is comfortable, it's too hot for my son to sit in the back row. If the air conditioner is turned on again, the front row will be too cold. Do you have any friends who have changed if you want to add air outlets to the back row?
    #1 sdhzlgl, Oct 20, 2019
  2. Tideland Prius
    16,051
    你可以英文問嗎?謝謝。
    #2 Tideland Prius, Oct 20, 2019
  3. Tideland Prius
    16,051
    Never mind, I’ll google translate it.
    “When the front seats are comfortable, my son in the rear is too hot. If I turn on the A/C, then the front seats are too cold. Has anyone added rear A/C vents?”
  4. sdhzlgl
    32
    montereypark
    It has been changed. Thanks for reminding.
  5. Tideland Prius
    16,051
    Awesome thanks! (Hopefully my mandarin was ok).
  6. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    You used traditional Chinese (more common in Taiwan). OP used simplified, but im sure it could be deciphered.
    Sadly I don't know the answer. Can only suggest "S-flow" be turned off (if it's on) and perhaps point the center vents towards the rear of the car.
    Tinting windows may help as well
    Tideland Prius likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,491
    14,099
    Tampa, FL
    Every car I've ever been in is like that, except for the big luxury SUVs with separate systems in the back. I can't think of any better advice than what @Tha_Ape said.
  8. bisco
    48,931
    can you not close the front vents like gen 3?
  9. sdhzlgl
    32
    montereypark
    I have tinted glass, but my son is afraid of heat and sweats easily. It seems that I need to modify it to add a rear air outlet.
  10. bisco
    48,931
    i stuffed foam in the front foot outlets
  11. Tideland Prius
    16,051
    Until you’ve modified it, can you close the side vents and blow the cold air through the centre vents to the rear? (Increase the fan speed so it gets to the rear, and hopefully the front isn’t as cold because you’ve closed the side vents).
    also make sure S-Flow is turned off
    jerrymildred likes this.
