Air ride 12V main power
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xjmyway, Mar 24, 2019.
  1. Xjmyway
    Xjmyway Junior Member
    22
    77
    San diego
    Quick question...is there a good 12V source near the trunk area to run compressors/controller or should I just run a dedicated line from the battery under the hood?
    What have you "air" people done for this?
    Longinus876 likes this.
  2. ChapmanF
    15,615
    Have you looked under the hood yet to see if there is a battery there?
    (Your profile says you have a Gen 3.)
    James Powers and orenji like this.
  3. jtchinoy
    jtchinoy New Member
    Hayward, California
    The Gen 3 Prius' battery is in the trunk, by the right tail light. Remove your hidden storage and the panel on the right to see it. If you prefer from the engine bay, there's a direct cable from the battery to the front inside the fuse box, under a black cover.
  4. Xjmyway
    22
    77
    San diego
    I "assumed" the battery was under the hood...actually glad it's in the truck, that makes it that much easier! Guess I haven't really looked ...Thanks!!!
  5. ChapmanF
    15,615
    Here's an air setup. (I don't use it for suspension though.)
  6. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    If you don't use this for the suspension, what do you use it for? Horns?
    James Powers likes this.
  7. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Please say horns, please say horns!
    Johnny Cakes and Grit like this.
  8. ChapmanF
    15,615
    Tires, blow gun (tree gunk out of window channels, grot underhood, etc.), impact wrench, air hammer, venturi vacuum, the usual stuff.
    No horns. I did buy the refurbished Viair from an online seller of horns, but I didn't buy their horns. I can do more stuff with tools than with horns.
    I don't think my setup would sound a horn very well. I think the horns take very high air flow for short bursts; the skinny spots in my lines would have too much pressure drop for that.
  9. ASRDogman
    6,091
    3,273
    So you'll use it for work... nifty. But, you can always ADD horns! :)
  10. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    HAHA!!!...
  11. ChapmanF
    15,615
    With the airflow restrictions in my setup, they'd sound like a drunken guy with no embouchure blowing into a tuba.
  12. ASRDogman
    6,091
    3,273
