airconditioning
Discussion in 'Gen 2 Prius Technical Discussion' started by jokaj, Apr 1, 2011.
  1. jokaj
    jokaj New Member
    Irvine
    does anyone know how the temperature setting works on the air conditioners? My wife and I have a bet. I say that when you set the temperature, the car will sense the cabin temp and adjust appropriately. She says that when you set the temperature, the air coming out is that temperature. Who is right?
    thanks
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You are. The temperature setting is the desired cabin temperature.
    Tom
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It also senses the sunlight. There is a sensor on the dash that will increase the cooling when in direct sunlight.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    You -could- take a thermometer and place it in the vent to prove you are right, but that probably wouldn't be a good idea. Just tell her she is right and let it be. You and she will be happier. ;)
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    +1 This is the one and only correct answer.
  6. jokaj
    jokaj New Member
    Irvine
    thanks for you response! that is what I thought.....maybe i call it a draw with the wife.....because I'll never win! :D
  7. magic-man
    magic-man New Member
    31
    Trinidad
    Wise choice! That's why I have been married so long ;)
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Try the thermometer to satisfy your own curiosity but keep the results to yourself. There is no advantage to proving a woman wrong except in a court of law, and even then there can be ugly consequences.
    Typical temperatures out of car AC ducts on a 100F + day with the AC set for comfort will be around 40F
