Aisin Water Pump Video with Coolant Bleed Instructions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Peter123, Jun 18, 2020.
  1. Peter123
    Peter123 Active Member
    131
    127
    Here is the video from Aisin, the original equipment manufacturer for the Prius water pump.
    In addition to instructions on changing out the water pump, it shows you how to bleed the coolant system.
    #1 Peter123, Jun 18, 2020
  2. KJ Fitz
    KJ Fitz Junior Member
    55
    Guam
    I just got a code to replace this pump.
    A thousand thanks for this step by step video!
  3. ChapmanF
    15,435
    The video's pretty good. It doesn't really mention that you do the engine warmup with the reservoir cap on. If you watch the video really closely, you can see that the cap is on; you get a really short glimpse of it behind his hand at about 3:16. So it's done correctly, but it would be better if he clearly said so, because people are often unsure whether the cap should be on or off for that part.
  4. KJ Fitz
    55
    Guam
    Dear Lord. The Dealer wanted $705 for the pump!
    NAPA Don't have one.
    I can wait a week to get the pump, thermostat and
    housing from rockauto.com for $300. Same Aisen part.
    I'm surprised they still even have a viable parts business,
    running markups like that, in an internet age.
  5. KJ Fitz
    55
    Guam
    Oh, and just for my own amusement, I inquired about labor? $400 to
    change the pump and service the coolant.
